Hi All,
I’m trying to set up LoRaWAN class B multicast using the LoRaMac-node repo. Joining the network and receiving beacons from the gateway all work fine. However, when I want to send a downlink using the Chirpstack Application server the gateway gives the following error (or actually a warning):
JSON down: {"txpk":{"imme":false,"rfch":0,"powe":14,"ant":0,"brd":0,"tmms":1294649730750,"freq":869.525,"modu":"LORA","datr":"SF12BW125","codr":"4/5","ipol":true,"size":13,"data":"YEvrFwCABgACLNaSjw=="}}
WARNING: [down] no mandatory "txpk.tmst" or "txpk.time" objects in JSON, TX aborted
The result is that the downlink is never send. Sending the same data using Class A works perfectly.
The gateway I’m using is the Kerlink Wirnet Station with the Chirpstack Gateway and the Semtech packet forwarder installed. For the packet forwarder I use this configuration file.
Any ideas what this could be? If more information is needed please let me know.
Thanks in advance,
Stan
