I am sending confirmed downlink to my Class C device But server is adding confirm downlink to Downlink queue .
Currently Using -
chirpstack-application-server version - 3.7.0-1-g6a9c690
chirpstack-network-server version - 3.6.0-2-g1d66d30
chirpstack-gateway-bridge version - 3.6.0
Device profile configuration - Class C, RX2 data-rate - 3, LoRaWAN MAC version - 1.0.1, LoRaWAN Regional Parameters revision - A
I’m facing this problem on my different chirpstack server versions which was working fine before and I did not made any changes. Now I have successfully restarted all services yet still facing the same issue.
“ChirpStack Network Server supports Class-C devices and uses the same Class-A downlink device-queue for Class-C downlink transmissions.”
Does that mean, that a downlink like a normal confirm also goes in the queue? Or is the queue exclusive only for triggered downlinks?
“[…] Until the frame has timed out, ChirpStack Network Server will wait with the transmission of the next downlink Class-C payload.”
I assume it is per device, right? So, if I would have x devices and sending downlinks to every device, than chirpstack will not wait for response or timeout from one device and all other have to wait for it, right?
