After a lot of tinkering and head-scratching I was able to solve the issue I was having with specifying channel subband on my gateway and the network server. Some minor changes to the comments would help a lot in case someone deals with the same issues in the future.
Currently the comments about enabled uplink channels looks like this:
https://www.loraserver.io/loraserver/install/config/
# Enable only a given sub-set of channels
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Note: when left blank, all channels will be enabled.
# Example:
# enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7]
enabled_uplink_channels=[]
in the quick-start guide we have this:
US915 configuration example
[network_server]
net_id="000000"
[network_server.band]
name="US_902_928"
I copied the example when setting my server up but didn’t fully realize that the channels != sub-band. Though much troubleshooting I had to figure out why sensors were joining on sub-band 2 but sending data from sub-band 1. (Sub-band terminology is present in Laird Sentrius sensors as well as Multitech gateways).
Adding a comment clarifying that in the US standard channels 0-7 corresponds to sub-band 1 and, for example, channels 8-15 correspond to sub-band 2 would have helped a lot in understanding how the configuration works.
To clarify for myself as well, are the 8 upstream 500kHz bandwidth channels (64 to 71) listed in the regional parameters included in this list and what is that channel used for?
