I’m trying to decode the ELV-LW-INT1 module using the manufacturer’s codec. However, this one was for the TTN.
I have already modified this for Chirpstack v4.
Unfortunately I get an error from time to time that I can’t solve any further.
Error:
“Evalulate script: Exception generated by QuickJS”
Here the modified codec:
* ELV-LW-INT1-Payload-Parser
* Version: V1.0
let firmwaretype = ["ELV-LW-INT1", "ELV-LW-INT1+DUS1", "ELV-LW-INT1+SoMo1", "ELV-LW-INT1+DUS1+SoMo1"];
function decodeUplink(input) {
return {
data: Decode(input.fPort, input.bytes, input.variables)
* @brief Receives the bytes transmitted from a ELV-LW-INT1
* @param bytes: Array with the data stream
* @param port: Used TTN/TTS data port
* @return Decoded data from the ELV-LW-INT1
function Decode(port, bytes, variables) {
var decoded = {}; // Container with the decoded output
var index = 2; // Index variable for the application data in the bytes[] array
var channel = 0; // Channel of Sensor
var Temp_Value = 0; // Variable for temporarily calculated values
var ID_device = 0;
var ID_DUS1 = 1;
var ID_SoMo1H = 2;
var ID_SoMo1T = 3;
if (port === 10) { // The default port for app data
if (bytes.length >= 2) { // Minimum 2 Bytes for Header
// Collecting header data
Temp_Value = (bytes[0] + 150);
Temp_Value *= 0.01; // Adjust the temperature resolution
decoded.Supply_Voltage= String(Temp_Value.toFixed(2));
//decoded.Supply_Voltage= String(Temp_Value.toFixed(2)) + " V";
if (bytes.length >= 3)
{ // There is not only the header data
switch (bytes[1])
case 0xff: //Device-Info
decoded.Frame_Type = "Device-Info";
Temp_Value = ( (bytes[2]<<16) + (bytes[3]<<8) + bytes[4] );
if (Temp_Value == 0x000215)
decoded.DeviceType = "ELV-LW-INT1";
else
decoded.DeviceType = ( String( Temp_Value ));
decoded.Application = ( String( bytes[5] ) + "." + String( bytes[6] ) + "." + String( bytes[7] ) );
decoded.Bootloader = ( String( bytes[8] ) + "." + String( bytes[9] ) + "." + String( bytes[10] ) );
decoded.Hardware = String.fromCharCode(bytes[11] + 0x40);//( String( bytes[11] ));
break;
case 0xfc: //Config-Info
decoded.Frame_Type = "Config-Info";
while (bytes.length > (index + 2))
channel = (bytes[index++]); //Channel ID überspringen
switch (bytes[index++]) //Sensor ID auswerten
case ID_device: //Device-Config
/*decoded.Device_Cyclic = bytes[index++];
decoded.Device_Statusmode = bytes[index++];
decoded.Device_Bitfield = bytes[index++];
decoded.IN1_Scan_Interval = bytes[index++];
decoded.IN2_Scan_Interval = bytes[index++];
decoded.IN1_Filtertime = bytes[index++];
decoded.IN2_Filtertime = bytes[index++];
decoded.SF = bytes[index++];
Temp_Value = (bytes[index]*256 + bytes[index+1]);
decoded.Rejoin_Time = Temp_Value
index++;
index++;*/
decoded.Device_Cyclic = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' Min';
decoded.Device_Statusmode = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.Device_Bitfield = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
if (bytes[index] & 0x80)
Temp_Value = (String(bytes[index] & 0x7f) + ' Min');
else
Temp_Value = (String(bytes[index] & 0x7f) + ' s');
decoded.IN1_Scan_Interval = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.IN2_Scan_Interval = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
if (bytes[index] == 0xff)
Temp_Value = "No TX Event";
else if (bytes[index] & 0x80)
else
decoded.IN1_Filtertime = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.IN2_Filtertime = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
if (bytes[index])
Temp_Value = String(bytes[index]);
else
Temp_Value = "ADR";
decoded.SF = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
Temp_Value = ((bytes[index] & 0x7f)*256 + bytes[index+1]);
{ //single
Temp_Value = (String(Temp_Value) + ' h');
else
{ //cyclic
if (Temp_Value)
else
Temp_Value = "Off";
decoded.Rejoin_Time = '0x'+(bytes[index]*256 + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String(Temp_Value);
index++;
index++;
break;
case ID_DUS1: //Channel DUS1 Config
/*decoded.DUS1_Cyclic = bytes[index++];
decoded.DUS1_Statusmode = bytes[index++];
decoded.DUS1_Messfilter = bytes[index++];
decoded.DUS1_Messinterval = bytes[index++];
decoded.DUS1_Messtrigger = bytes[index++];
decoded.DUS1_Threshold_1 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.DUS1_Threshold_2 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.DUS1_Delta = (bytes[index]*256 + bytes[index+1]);
index++;
index++;
decoded.DUS1_Filtertime_Thr1 = bytes[index++];
decoded.DUS1_Filtertime_Thr2 = bytes[index++];
decoded.DUS1_Filtertime_Delta = bytes[index++];
decoded.DUS1_Ref_Level_0 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.DUS1_Ref_Level_1 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;*/
decoded.DUS1_Cyclic = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' Min';
decoded.DUS1_Statusmode = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.DUS1_Messfilter = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
else
decoded.DUS1_Messinterval = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
decoded.DUS1_Messtrigger = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.DUS1_Threshold_1 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]) + ' mm';
index++;
index++;
decoded.DUS1_Threshold_2 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]) + ' mm';
index++;
index++;
decoded.DUS1_Delta = '0x'+(bytes[index]*256 + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]) + ' mm';
index++;
index++;
else
decoded.DUS1_Filtertime_Thr1 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.DUS1_Filtertime_Thr2 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
Temp_Value = String(bytes[index] & 0x7f) + ' Min';
else
Temp_Value = String(bytes[index] & 0x7f) + ' s';
decoded.DUS1_Filtertime_Delta = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
decoded.DUS1_Ref_Level_0 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.DUS1_Ref_Level_1 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]);
index++;
index++;
break;
case ID_SoMo1H: //Channel SoMo1H Config
/*decoded.SoMo1H_Cyclic = bytes[index++];
decoded.SoMo1H_Statusmode = bytes[index++];
decoded.SoMo1H_Messfilter = bytes[index++];
decoded.SoMo1H_Messinterval = bytes[index++];
decoded.SoMo1H_Messtrigger = bytes[index++];
decoded.SoMo1H_Threshold_1 = bytes[index++];
decoded.SoMo1H_Threshold_2 = bytes[index++];
decoded.SoMo1H_Delta = bytes[index++];
decoded.SoMo1H_Filtertime_Thr1 = bytes[index++];
decoded.SoMo1H_Filtertime_Thr2 = bytes[index++];
decoded.SoMo1H_Filtertime_Delta = bytes[index++];
decoded.SoMo1H_Ref_Level_0 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.SoMo1H_Ref_Level_1 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;*/
decoded.SoMo1H_Cyclic = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' Min';
decoded.SoMo1H_Statusmode = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.SoMo1H_Messfilter = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
else
decoded.SoMo1H_Messinterval = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
decoded.SoMo1H_Messtrigger = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.SoMo1H_Threshold_1 = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' %';
decoded.SoMo1H_Threshold_2 = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' %';
decoded.SoMo1H_Delta = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' %';
else
decoded.SoMo1H_Filtertime_Thr1 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.SoMo1H_Filtertime_Thr2 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.SoMo1H_Filtertime_Delta = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
decoded.SoMo1H_Ref_Level_0 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.SoMo1H_Ref_Level_1 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String((bytes[index]*256) + bytes[index+1]);
index++;
index++;
break;
case ID_SoMo1T: //Channel SoMo1T Config
/*decoded.SoMo1T_Cyclic = bytes[index++];
decoded.SoMo1T_Statusmode = bytes[index++];
decoded.SoMo1T_Messfilter = bytes[index++];
decoded.SoMo1T_Messinterval = bytes[index++];
decoded.SoMo1T_Messtrigger = bytes[index++];
decoded.SoMo1T_Threshold_1 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.SoMo1T_Threshold_2 = ((bytes[index]*256) + bytes[index+1]);
index++;
index++;
decoded.SoMo1T_Delta = (bytes[index]*256 + bytes[index+1]);
index++;
index++;
decoded.SoMo1T_Filtertime_Thr1 = bytes[index++];
decoded.SoMo1T_Filtertime_Thr2 = bytes[index++];
decoded.SoMo1T_Filtertime_Delta = bytes[index++];*/
decoded.SoMo1T_Cyclic = '0x'+(bytes[index]).toString(16).padStart(2,'0') + ' ' + String(bytes[index++]) + ' Min';
decoded.SoMo1T_Statusmode = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
decoded.SoMo1T_Messfilter = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
else
decoded.SoMo1T_Messinterval = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
decoded.SoMo1T_Messtrigger = '0x'+(bytes[index++]).toString(16).padStart(2,'0');
Temp_Value = ((bytes[index]*256) + bytes[index+1]);
if (Temp_Value > 0x7fff) {
Temp_Value -= 0x10000;
Temp_Value *= 0.1; // Adjust the temperature resolution
Temp_Value = String(Temp_Value.toFixed(1)) + " °C";
decoded.SoMo1T_Threshold_1 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String(Temp_Value);
index++;
index++;
decoded.SoMo1T_Threshold_2 = '0x'+((bytes[index]*256) + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String(Temp_Value);
index++;
index++;
decoded.SoMo1T_Delta = '0x'+(bytes[index]*256 + bytes[index+1]).toString(16).padStart(4,'0') + ' ' + String(Temp_Value);
index++;
index++;
else
decoded.SoMo1T_Filtertime_Thr1 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.SoMo1T_Filtertime_Thr2 = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
else
decoded.SoMo1T_Filtertime_Delta = '0x'+(bytes[index++]).toString(16).padStart(2,'0') + ' ' + String(Temp_Value);
break;
default:
// Clear all properties from the "decoded" object
decoded = {};
// Add error code propertiy to the "decoded" object
decoded.parser_error = "Wrong Config-Info Channel or Data";
break;
break;
case 0x00: //Status-Info
decoded.Frame_Type = "Status-Info";
// Loop for collecting the application data
case ID_device: //Device-Status-Info
if (bytes[index] & 0x01) {
decoded.Device_Event_Cyclic = "Y";
else {
decoded.Device_Event_Cyclic = "N";
if (bytes[index] & 0x02) {
decoded.Device_Event_Boot = "Y";
else {
decoded.Device_Event_Boot = "N";
if (bytes[index] & 0x04) {
decoded.Device_Event_Heartbeat = "Y";
else {
decoded.Device_Event_Heartbeat = "N";
if (bytes[index] & 0x08) {
decoded.Device_Event_Button = "Y";
else {
decoded.Device_Event_Button = "N";
if (bytes[index] & 0x10) {
decoded.Device_Event_IN1 = "Y";
else {
decoded.Device_Event_IN1 = "N";
if (bytes[index] & 0x20) {
decoded.Device_Event_IN2 = "Y";
else {
decoded.Device_Event_IN2 = "N";
decoded.Device_Eventflags = bytes[index];
index++;
decoded.IN1_Level = "Hi";
else {
decoded.IN1_Level = "Lo";
decoded.IN2_Level = "Hi";
else {
decoded.IN2_Level = "Lo";
decoded.IN1_Change = "Y";
else {
decoded.IN1_Change = "N";
decoded.IN2_Change = "Y";
else {
decoded.IN2_Change = "N";
decoded.Device_InputStates = bytes[index];
index++;
break;
case ID_DUS1: //DUS1-Status-Info
decoded.DUS1_Event_Cyclic = "Y";
else {
decoded.DUS1_Event_Cyclic = "N";
decoded.DUS1_Event_Boot = "Y";
else {
decoded.DUS1_Event_Boot = "N";
decoded.DUS1_Event_Threshold_1 = "Y";
else {
decoded.DUS1_Event_Threshold_1 = "N";
decoded.DUS1_Event_Threshold_2 = "Y";
else {
decoded.DUS1_Event_Threshold_2 = "N";
if (bytes[index] & 0x40) {
decoded.DUS1_Event_Threshold_Delta = "Y";
else {
decoded.DUS1_Event_Threshold_Delta = "N";
if (bytes[index] & 0x80) {
decoded.DUS1_Event_Error = "Y";
else {
decoded.DUS1_Event_Error = "N";
decoded.DUS1_Eventflags = bytes[index];
index++;
Temp_Value = (bytes[index++] * 256);
Temp_Value += bytes[index++];
if (Temp_Value == 8000)
decoded.DUS1_Distance = "Error"
else if (Temp_Value == 7999)
decoded.DUS1_Distance = "Unknown"
else if (Temp_Value == 7501)
decoded.DUS1_Distance = "Overflow"
else
decoded.DUS1_Distance = Temp_Value;
//decoded.DUS1_Distance_String = String(Temp_Value) + " mm";
if (bytes[index] == 255)
decoded.DUS1_Level = "Error"
else if (bytes[index] == 254)
decoded.DUS1_Level = "Unknown"
else if (bytes[index] <= 100)
decoded.DUS1_Level = bytes[index];
//decoded.DUS1_Level_String = String(bytes[index]) + " %";
index++;
break;
Does anyone have an idea where the problem is ?
Thanks
