I am struggling with receiving data from RFM-LR1 B-meter. I have tried the below mentioned codec but it is giving an error
type:“UPLINK_CODEC”
error:“execute js error: js vm error: (anonymous): Line 1:2 Unexpected token * (and 5 more errors)”
Does anybody have a working codec for this device?
The codec used currently is:
function decodeUplink(input) {
var decoded = {
cpu_voltage: null,
cpu_temperature: null,
alarm_leakage: null,
alarm_removal: null,
alarm_magnetic: null,
alarm_excess_flow: null,
volume: null,
backflow_volume: null
const bytes = input.bytes;
var idx = 0;
// loop through message getting any data
while (idx < bytes.length) {
if (bytes[idx++] == 0x01) {
// then it's some data
var data_type = bytes[idx++];
switch (data_type) {
case 0x03:
idx += 6;
break;
case 0x05:
break;
case 0x06:
// cpu voltage
decoded.cpu_voltage = bytes[idx++] / 40; // 25mV per bit
break;
case 0x0A:
// cpu temperature
decoded.cpu_temperature = (((bytes[idx++] << 8) | bytes[idx++]) / 100) - 50; // 0.01c per bit offset of 50
break;
case 0x20:
// alarms
decoded.alarm_leakage = bytes[idx] & 0x01;
decoded.alarm_removal = bytes[idx] & 0x08;
decoded.alarm_magnetic = bytes[idx] & 0x20;
decoded.alarm_excess_flow = bytes[idx] & 0x80;
idx++;
break;
case 0x21:
// volume
decoded.volume = ((bytes[idx++] << 24) | (bytes[idx++] << 16) | (bytes[idx++] << 8) | bytes[idx++]) * 0.001;
break;
case 0x27:
// back flow volume
decoded.backflow_volume = ((bytes[idx++] << 24) | (bytes[idx++] << 16) | (bytes[idx++] << 8) | bytes[idx++]) * 0.001;
break;
case 0x22:
case 0x2B:
idx += 2;
break;
case 0x25:
idx += 4;
break;
case 0x2C:
case 0x2D:
idx++;
break;
default:
break;
return { data: decoded };
