Hi @brocaar can you please tell me how to import libraries into the codec function area:
This is a very generic question - did you read this?
I can add to that:
- be sure to provide entry-point (function name) that ChirpStack is expecting - just call decoder function, if it lacks ChirpStack support.
- natively Base64-encoded payload is decoded for you - your function should expect binary data
- for now, be sure that the JavaScript decoder is strictly ES5.
- I used to wonder why some vendors’ devices had multiple codecs floating on github until I discovered above limitation. But with that in mind, if one decoder doesn’t work then keep looking and see if someone hasn’t hacked a version that does!
- If you’re not skilled in JavaScript (me neither) then your other option is to keep payload in Base64 and decode it in your end-application (jython, for me).
This is not possible.
All good. Thank you.
