I send an int i = 850 from my node, but the problem is that I get the JSON data in ASCII format in my php page! and so I make a conversion ascii => decimal with this function :
$data64 = $var['data'];
$data8 = base64_decode($data64) ;
$code = str_split($data8);
$data ="";
for($i=0; $i< sizeof($code) ; $i++)
$data = $data . ord($code[$i]);
I can not make a JavaScript program in the integration part.
the ascii format limits me, and I can not send a “float” or “int” that exceeds “256” can you help me to solve this problem so that I can send “int” or “float” without limitation.
If your JSON is like:
“data” = “850”,
then the variable $data8 contains the value 850.
unfortunately the variable $data8 contains a data in ascii format and which does not represent 850
can you show what’s stored in $data8?
$data8 = 4 ! (4 in ascii) there are any relation with 850 ! I will show you my c code of my node
my goal is to send a float from my node, so I use a byte array.
my float is 4 bytes, the stack I’m using " STM32CubeExpansion_LRWAN_V1.2.1 ", is made to send a byte array of int.
C code in my NODE :
static uint8_t AppDataBuff[64];
uint32_t humidity_int = 0;
float humidity = 25.6;
humidity_int = (humidity * 32) + 1;
AppData.Buff[i++] = humidity_int >> 24 ;
AppData.Buff[i++] = humidity_int >> 16 ;
AppData.Buff[i++] = humidity_int >> 8 ;
AppData.Buff[i] = humidity_int ;
AppData.BuffSize = i;
LORA_send( &AppData, LORAWAN_DEFAULT_CONFIRM_MSG_STATE);
so i’m going to multiply in the node and split in my application to get the commaso:
first I transform it into “int” with the line :
humidity_int = (humidity * 32) + 1; //possible to multiply it just x10 too
then I introduce my four byte float into the byte array one by one.
unfortunately I do not know what to do in the JavaScript part to decode my information, i try this :
var humidity_byte = bytes[0] << 24 | bytes[1] << 16 | bytes[2] << 8 | bytes[3] ;
var humidity = humidity_byte / 32;
return {
"humidity ": humidity ,
I am not a specialist in JavaScript, can you help me to decode my data please.
I obtain this result
humidity :24, normally I have to get 25.6
I resolve the error, it was an error in my C code, i did not increment the last byte in the byte array :
