Hello guys,
I managed to setup a lora server with my end device. I was able to communicate (the end-device turns on a led when it receives a frame with a particular payload, say 0x10).
I moved my end device to another floor, and the communication started failing (the end-device light never went on) . I thought the device was out of range but when I checked the logs, I saw that the end-device and loraserver were able to communicate, but the received payload on the end-device side wasn’t the expected one. Instead of 0x10, I got a random value each time different.
I started to have a closer look at the received frames. Each time the end-devices reboots, a new JoinRequest is made, and I can see the JoinAccept that is received. For example for 2 consecutives reboots, I get:
decoding from Base64: AEFYSU9NLUxHAAIVdAQAAAAGTpiXwf8=
Decoded packet
Message Type = Join Request
AppEUI = 474C2D4D4F495841
DevEUI = 0000000474150200
DevNonce = 4E06
MIC = 9897C1FF
decoding from Base64: IEa40vVaMmp08hseQe9ZqRE=
Decoded packet
Message Type = Join Accept
AppNonce = D2B846
NetID = 325AF5
DevAddr = 1BF2746A
MIC = EF59A911
decoding from Base64: AEFYSU9NLUxHAAIVdAQAAAB/9bbFjbk=
Decoded packet
DevNonce = F57F
MIC = B6C58DB9
decoding from Base64: IGuhOhJ66DSn0l7evxZCFdU=
Decoded packet
AppNonce = 3AA16B
NetID = E87A12
DevAddr = 5ED2A734
MIC = 164215D5
So this seems correct to me, a new DevAddr is generated at each reboot. But when I looked at the frame that should turn on the light, I noticed it was always the same physicial payload.
decoding from Base64: oF8OdQaAAQAKaDnuMcva
Decoded packet
Message Type = Data
PHYPayload = A05F0E75068001000A6839EE31CBDA
( PHYPayload = MHDR[1] | MACPayload[..] | MIC[4] )
MHDR = A0
MACPayload = 5F0E75068001000A6839
MIC = EE31CBDA
( MACPayload = FHDR | FPort | FRMPayload )
FHDR = 5F0E7506800100
FPort = 0A
FRMPayload = 6839
( FHDR = DevAddr[4] | FCtrl[1] | FCnt[2] | FOpts[0..15] )
DevAddr = 06750E5F (Big Endian)
FCtrl = 80
FCnt = 0001 (Big Endian)
FOpts =
Message Type = Confirmed Data Down
Direction = down
FCnt = 1
FCtrl.ACK = false
FCtrl.ADR = true
Isn’t the physicial payload supposed to change when a new DevAddr is issued ? And the DevAddr contained in the frame (06750E5F) isn’t the same as the one received in the JoinAccept. So actually I get all the time the same frame, but my end-device uses the DevAddr received in the JoinAccept to decrypt the payload, so the decrypted value always differ, so my end-device doesn’t turn light on.
Would it be possible that the LoRa Server keeps an old DevAddr in cache or something ?
