If the device stops transmitting, then it might be a problem with the device. I can’t reproduce the issue as I don’t have this device to test with.
If the device is not at fault, I would guess that the problem is that the gateway’s channel configuration is not the same as Loraserver’s gateway configuration. Make sure that loraserver is aware that the channels being used are 56-63.
