Hello!
I have a custom SoM (T113-S3, OpenWRT 24.04, Kernel 6.6.29, SX1302 Waveshare module)
Concentratord builded as OpenWRT package (GitHub - chirpstack/chirpstack-openwrt-feed: OpenWrt packages feed containing the ChirpStack packages.)
Concentratord can’t init the GPIO pins, repeat it every 5sec
[ 3205.215295] gpio gpiochip0: registered chardev handle for 1 lines
[ 3211.117346] sun20i-d1-pinctrl 2000000.pinctrl: request pin 99 (PD3) for 2000000.pinctrl:99
[ 3211.125681] gpio gpiochip0: Persistence not supported for GPIO 99
[ 3211.131791] gpio gpiochip0: registered chardev handle for line 99
[ 3211.137939] gpio gpiochip0: registered chardev handle for 1 lines
[ 3211.144412] sun20i-d1-pinctrl 2000000.pinctrl: request pin 100 (PD4) for 2000000.pinctrl:100
[ 3211.152899] gpio gpiochip0: Persistence not supported for GPIO 100
[ 3211.159112] gpio gpiochip0: registered chardev handle for line 100
[ 3211.165327] gpio gpiochip0: registered chardev handle for 1 lines
[ 3217.078224] sun20i-d1-pinctrl 2000000.pinctrl: request pin 99 (PD3) for 2000000.pinctrl:99
[ 3217.086556] gpio gpiochip0: Persistence not supported for GPIO 99
[ 3217.092663] gpio gpiochip0: registered chardev handle for line 99
[ 3217.098796] gpio gpiochip0: registered chardev handle for 1 lines
[ 3217.105275] sun20i-d1-pinctrl 2000000.pinctrl: request pin 100 (PD4) for 2000000.pinctrl:100
[ 3217.113732] gpio gpiochip0: Persistence not supported for GPIO 100
[ 3217.119975] gpio gpiochip0: registered chardev handle for line 100
[ 3217.126196] gpio gpiochip0: registered chardev handle for 1 lines
[ 3223.017304] sun20i-d1-pinctrl 2000000.pinctrl: request pin 99 (PD3) for 2000000.pinctrl:99
[ 3223.025643] gpio gpiochip0: Persistence not supported for GPIO 99
[ 3223.031753] gpio gpiochip0: registered chardev handle for line 99
[ 3223.037914] gpio gpiochip0: registered chardev handle for 1 lines
[ 3223.044386] sun20i-d1-pinctrl 2000000.pinctrl: request pin 100 (PD4) for 2000000.pinctrl:100
[ 3223.052879] gpio gpiochip0: Persistence not supported for GPIO 100
[ 3223.059091] gpio gpiochip0: registered chardev handle for line 100
[ 3223.065303] gpio gpiochip0: registered chardev handle for 1 lines
[ 3228.957378] sun20i-d1-pinctrl 2000000.pinctrl: request pin 99 (PD3) for 2000000.pinctrl:99
root@OpenWrt:~# gpioinfo
gpiochip0 - 224 lines:
line 0: unnamed input
line 1: unnamed input
line 98: unnamed input
line 99: unnamed output
line 100: unnamed output
line 101: unnamed input
line 102: unnamed input
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring reset pin, dev: /dev/gpiochip0, pin: 99
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3977.977394] sun20i-d1-pinctrl 2000000.pinctrl: request pin 99 (PD3) for 2000000.pinctrl:99
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3977.985828] gpio gpiochip0: Persistence not supported for GPIO 99
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3977.991937] gpio gpiochip0: registered chardev handle for line 99
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3977.998075] gpio gpiochip0: registered chardev handle for 1 lines
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring sx1302 power enable pin, dev: /dev/gpiochip0, pin: 100
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3978.004767] sun20i-d1-pinctrl 2000000.pinctrl: request pin 100 (PD4) for 2000000.pinctrl:100
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3978.013230] gpio gpiochip0: Persistence not supported for GPIO 100
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3978.019514] gpio gpiochip0: registered chardev handle for line 100
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Starting Concentratord SX1302 (version: 4.4.7, docs: https://www.chirpstack.io/docs/chirpstack-concentratord/)
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Enabling concentrator power
Wed Feb 19 07:29:04 2025 kern.debug kernel: [ 3978.025736] gpio gpiochip0: registered chardev handle for 1 lines
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Triggering sx130x reset
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Setting i2c device path, path: /dev/i2c-1
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Setting i2c temperature sensor address, address: 57
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Setting board configuration, lorawan_public: true, clock_source: 0, com_type: Spi, com_path: /dev/spidev1.0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Setting up fine timestamp, enable: false
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Setting up concentrator channels
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring radio, radio: 0, enabled: true, center_freq: 869300000, type: SX1250
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring radio, radio: 1, enabled: false, center_freq: 0, type: SX1250
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868900000, rf_chain: 0, if_freq: -400000
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 869100000, rf_chain: 0, if_freq: -200000
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 2, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 3, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 4, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 5, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 6, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring multi-SF LoRa channel, channel: 7, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring Std LoRa channel, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
Wed Feb 19 07:29:04 2025 user.info chirpstack-concentratord-sx1302[12633]: Configuring FSK channel, enabled: false, freq: 0, rf_chain: 0, if_freq: 0
What is wrong?
