Hello!
I am using the Chirpstack OS on a Raspberry pi 4 with a WM1302 LoRaWAN gateway module from seeed studio. All services (network server, gateway bridge, and application server) display an OK status, except for the concentratord. I selected the LoRa concentrator shield to be the Semtech SX1302 CoreCell from the shield list because the WM1302 is based on that chip. I already configured all frequencies and channels for the US915 configuration. I had added a gateway profile in the app server under “Gateway-profiles”, but after some reading on other user’s similar issues I deleted the profile and just left the gateway config under “Gateways” to avoid any connection issues between the app server and the concentratord daemon. I am not able to see the Gateway ID (displays “not configured”) although I already added it to the Concentratord Config file and made sure it matched with the gateway config on the ChirpStack Application Server.
I also changed the reset pins as specified on here https://wiki.seeedstudio.com/WM1302_module/
Does anyone know what could be the issue and how I could solve this? I would really appreciate your help and input.
Jul 27 23:00:52 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:00:52.148454957Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:00:55 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:00:55.661600549Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:00:59 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:00:59.173927157Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:02 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:02.685059602Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:06 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:06.19703249Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial uni
Jul 27 23:01:09 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:09.708956758Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:13 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:13.222912975Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:14 raspberrypi4 user.err monit[494]: 'chirpstack-concentratord' failed to start (exit status 0) -- '/etc/init.d/chirpstack-concentratord start': Starting chirpstack-concentratord
Jul 27 23:01:16 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:16.736084417Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:19 raspberrypi4 authpriv.notice sudo: admin : TTY=pts/0 ; PWD=/home/admin ; USER=root ; COMMAND=/usr/bin/tail -f /var/log/messages
Jul 27 23:01:20 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:20.249138671Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:23 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:23.761406469Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:24 raspberrypi4 user.err monit[494]: 'chirpstack-concentratord' process is not running
Jul 27 23:01:24 raspberrypi4 user.info monit[494]: 'chirpstack-concentratord' trying to restart
Jul 27 23:01:24 raspberrypi4 user.info monit[494]: 'chirpstack-concentratord' start: '/etc/init.d/chirpstack-concentratord start'
Jul 27 23:01:27 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:27.272203099Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:30 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:30.781449378Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:34 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:34.292304674Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:37 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:37.805944639Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:41 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:41.318068053Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:44 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:44.830878814Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:48 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:48.341573534Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:51 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:51.852926401Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:54 raspberrypi4 user.err monit[494]: 'chirpstack-concentratord' failed to start (exit status 0) -- '/etc/init.d/chirpstack-concentratord start': Starting chirpstack-concentratord
Jul 27 23:01:55 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:55.364553697Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:01:58 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:01:58.876546109Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:02 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:02.388316275Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:04 raspberrypi4 user.err monit[494]: 'chirpstack-concentratord' process is not running
Jul 27 23:02:04 raspberrypi4 user.info monit[494]: 'chirpstack-concentratord' trying to restart
Jul 27 23:02:04 raspberrypi4 user.info monit[494]: 'chirpstack-concentratord' start: '/etc/init.d/chirpstack-concentratord start'
Jul 27 23:02:05 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:05.900568186Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:09 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:09.413878985Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:12 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:12.924282114Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:16 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:16.436549917Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:19 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:19.947627974Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:23 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:23.459694886Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:26 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:26.970969346Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Jul 27 23:02:30 raspberrypi4 user.err chirpstack-gateway-bridge[637]: time="2022-07-27T23:02:30.483356716Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Thank you!
