Hello @brocaar
Some test findings I made.
Rasp0-wifi
the configuration setup does not generate the gatewayID via the wifi mac.
I use the RHF0M301 with the AU915 band
in the settings menu of GatewayOS there is no Band Au915
I did the manual configuration it worked perfectly
however, when I use the Flag GNSS to enable GPS, the concentratord does not start.
if I remove the flag it will work normally again
I tried with Rasp3 and it was the same thing.
