Hello everyone. My company is interested in buying the RAK Wisgate Edge Pro LoRaWAN Gateway. This is a 16 channel gateway that supports two antennas.
We are thinking about using two different gain antennas with this gateway, a low gain antenna for close by devices and a high gain antenna for devices that are far away.
I asked RAK about the feasibility of this being possible and they told me I have to make additional configurations on my LNS to achieve two different 8 channel concentrators to act as two different gateways with different gain antennas.
Can anyone tell me if this is possible and how i should go about doing this.
Edit: We have a Chirpstack instance deployed
I believe this gateway has two slots for LoRa concentrator cards, which can be used individually so effectively you can create two individual gateways within a single box
So your setup would look like:
- Packet forwarder for Slot 1 → ChirpStack
- Packet forwarder for Slot 2 → ChirpStack
From the ChirpStack side, you will configure two individual gateways.
Thank you for your response. My next question is related to achieving multiple sub-bands in my Chirpstack instance. Currently, I’m using a Docker stack with US915 sub-band 1. How can I configure it to use other sub-bands?
Here’s my current gateway-bridge configuration for reference:
servers=["tcp://mosquitto:1883"]
username=""
password=""
[integration.mqtt]
event_topic_template="us915_1/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
state_topic_template="us915_1/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
command_topic_template="us915_1/gateway/{{ .GatewayID }}/command/#"
Any guidance on configuring multiple sub-bands would be appreciated.
Make sure the other sub-band(s) are enabled in the ChirpStack configuration and make sure your ChirpStack Gateway Bridge instances are forwarding to the correct MQTT topics.
Each sub-band would need its own ChirpStack Gateway Bridge instance.
