Hello.
I try to establish a connection between loraserver and gateway-bridge, which are installed in different hosts.
More specifically, in host A (with ip 192.168.1.18) i installed loraserver,lora-app-server-postgresql,redis and mqtt broker(+client), while in host B (a RPI 3) i installed lora-gateway-bridge,mqtt and packet forwarder.
My question has to do with the configuration of lora-gateway-bridge.toml file…As mqtt broker run in Host A, i have to specify it, with its IP:
in [backend.mqtt] change line of server as:
server="tcp://192.168.1.8:1883"
(the IP of Host A), instead of 127.0.0.1 as i don’t install in the same machine loraserver and lora-gateway-bridge.
If anything is wrong please correct me.
Thanks in advance,
Nikos.
