I hope i hit the right category.
We are currently troubleshooting on some network issues. We were wondering if it is possible to configure or see what TX power is being used? Formerly, i believe it could be adjusted in the loraserver.toml and in there in “downlink_tx_power”.
Thanks’
For the default PA, a TX power configuration consists of the parameters as described below. When all parameters are set, a resulting 16-bit hexadecimal value represents the TX power configuration. This 16-bit hexadecimal is contained in the txPower variable in your radio setup command.
I believe i found it as an option in the “chirpstack-network-server.toml”:
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
