Configure TLS options for server
Hello guys!
I need disable the use of TLSv1.0 and activate the protocol TLSv1.2 instead, and I don’t know configurate this on the lora-app-server.toml, somebody can I help me?
Thx
LoRa App Server does not expose low-level TLS configuration, the webserver uses the defaults as provided by the Go net/http webserver. One option would to run LoRa App Server without TLS and add a proxy (e.g. NGINX) which gives you a finer control of TLS configuration.
Hello guys!
I need disable and stop using DES, 3DES, IDEA or RC2 ciphers, and I don’t know configurate this on the lora-app-server.toml, somebody can I help me?
Thx
I’ve merged your topics. Please see the above suggestion.
Man, thank you for your help.
Do you know any doc with I can use to configure NGINX to control the TLS ?
Thx
See:
I will test and soon I give a response.
Thanks man,
Hello there!
I was able to configurate Nginx but how I can run LoRa App Server without TLS, it is some configuration on /etc/lora-app-server/lora-app-server.toml ?
Please see https://www.loraserver.io/lora-app-server/install/config/, the default configuration is (now) without TLS.
What is the default configuration for the Go net/http webserver?
Example, I need to disabled TLS 1.0 and TLS 1.1 for the port 8000 and 8001.
The default ChirpStack configuration is without TLS disabled.
