Confusion about the different packages
I’m pretty new to LoraWAN and I’ve been reading https://www.chirpstack.io/docs/architecture.html but I’m still a little bit confused about the different packages.
A customer of mine installed Semtech BasicStation on a PC-Engines board. Because we would like to have more gateways like this, we decided that I would install Chirpstack with the gateway bridge on a server and let the customer connect his gatway to our private Chirpstack installation. Based on the Architecture page of the documentation, we are trying Multi-region example 1.
I followed https://www.chirpstack.io/docs/getting-started/docker.html to install on our server with docker. I cloned https://github.com/chirpstack/chirpstack-docker.git and made a couple of smaller changes and started it with docker-compose start.
My docker-compose looks like this:
version: "3"
services:
  chirpstack:
    image: chirpstack/chirpstack:4.2.0
    command: -c /etc/chirpstack
    restart: unless-stopped
    security_opt:
      - apparmor:unconfined
    volumes:
      - ./lorawan-devices:/opt/lorawan-devices
    depends_on:
      - postgres
      - mosquitto
      - redis
    environment:
      - MQTT_BROKER_HOST=mosquitto
      - REDIS_HOST=redis
      - POSTGRESQL_HOST=postgres
    ports:
      - 8080:8080
  chirpstack-gateway-bridge-eu868:
    image: chirpstack/chirpstack-gateway-bridge:4.0.6
    security_opt:
    ports:
      - 1700:1700/udp
    volumes:
      - ./configuration/chirpstack-gateway-bridge-eu868:/etc/chirpstack-gateway-bridge
    depends_on:
      - mosquitto
  chirpstack-gateway-bridge-eu433:
    security_opt:
    ports:
      - 1701:1700/udp
    volumes:
      - ./configuration/chirpstack-gateway-bridge-eu433:/etc/chirpstack-gateway-bridge
    depends_on:
      - mosquitto
  chirpstack-rest-api:
    image: chirpstack/chirpstack-rest-api:4.2.0
    security_opt:
    command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
    ports:
      - 8090:8090
    depends_on:
      - chirpstack
  postgres:
    image: postgres:14-alpine
    security_opt:
    volumes:
    environment:
      - POSTGRES_PASSWORD=root
  redis:
    image: redis:7-alpine
    security_opt:
    volumes:
      - redisdata:/data
  mosquitto:
    image: eclipse-mosquitto:2
    security_opt:
    ports:
      - 1883:1883
    volumes:
      - ./configuration/mosquitto/mosquitto.conf:/mosquitto/config/mosquitto.conf
volumes:
  postgresqldata:
  redisdata:
so more or less the same configuration as the one in https://github.com/chirpstack/chirpstack-docker.git
On the host I also have an nginx with this configuration:
upstream chirpstack-app {
    server localhost:8080;
server {
    listen 443 default_server ssl;
    listen [::]:443 default_server ssl;
    server_name chirpstack.mycomapny.tdl;
    access_log  /var/log/nginx/ssl_chirpstack-access.log;
    error_log  /var/log/nginx/ssl_chirpstack-error.log;
    ssl_certificate     /etc/letsencrypt/live/chirpstack.mycomapny.tdl/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/chirpstack.mycomapny.tdl/privkey.pem;
    location / {
        proxy_cache off;
        proxy_pass http://chirpstack-app;
        include /etc/nginx/proxy_params;
        proxy_read_timeout 3600;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "Upgrade";
This seems to work, I was able to log in via https://chirpstack.mycomapny.tdl and change the admin password.
So then I wanted to connect the customer gateway with our chirpstack installation but that’s where I got confused.
Looking at https://www.chirpstack.io/docs/chirpstack/configuration.html specially the gateway section, it says:
Global gateway configuration.
Please note that backend configuration can be found in the per-region
configuration.
I’m confused:
  • why does it have a gateway section? Is this the same gateway as the chirpstack/chirpstack-gateway-bridge image?
  • there is the configuration file configuration/chirpstack/chirpstack.toml but also configuration/chirpstack/region_eu868.toml where there is the regions.gateway section.
  • there is configuration/chirpstack-gateway-bridge-eu868/chirpstack-gateway-bridge.toml which in my case it looks like this:
    servers=["tcp://mosquitto:1883"]
    username=""
    password=""
    [integration.mqtt]
    event_topic_template="eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
    state_topic_template="eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
    command_topic_template="eu868/gateway/{{ .GatewayID }}/command/#"
Why are there so many gateways and do I need all of these?
Regarding SSL certificates: here I’m confused as well.
Again, looking at https://www.chirpstack.io/docs/chirpstack/configuration.html and the gateway section, you can specify the ca_key and ca_cert values (are those the paths to the files?). These do not have anything to do with the TLS Certificates that I get from Let’s encrypt?
Semtech BasicStation documentation says that if you want TLS Server and Client Authentication, you need to provide the tc.trust file (https://letsencrypt.org/certs/isrgrootx1.pem), but also tc.crt which is the The Station’s own certificate. Is this signed with the CA specificed in the gateway.ca_cert section?
Thanks.
PS: Why am I getting this error An error occurred: Sorry, new users can only put 2 links in a post? I had to put all hyperlinks in backticks.
Let’s try to sort it out.
The gateway section of the main configuration file is used to setup server certificates for the gateways (path to files). You can also specify here the lifetime of the gateway certificates. See: Configuration - ChirpStack open-source LoRaWAN® Network Server documentation
The chirpstack-gateway-bridge.toml is the main configuration file of each gateway when the gateway bridge is installed on a “physical gateway” or on your server (see: Configuration - ChirpStack open-source LoRaWAN® Network Server documentation). This is also where you specify the path of the MQTT client certificates generated from the interface.
The region configuration file is focused on the local parameters. That mean that you can customized it depending on the region. This is also where you can setup your frequency plan.
Regarding Let’s encrypt, it has nothing to do with those files. You must deal with that on the NGINX/apache side as you did.
Hope this helps.
Hi Jerome,
thanks for your reply.
So that means that in order to do authentication, I need to create a CA and a client certificate on the server side. And on the gateway side, I need to create a CSR and sign it with the CA of the server? What is the Common Name for the server certificate? The domain name? Should I also use SAN?
You should try this: Mosquitto TLS configuration - ChirpStack open-source LoRaWAN® Network Server documentation
Hi Jerome,
thanks, that helps. I’ll try that.
