I’m getting errors on state publish- here are the logs
INFO[0000] starting ChirpStack Gateway Bridge docs="https://www.chirpstack.io/gateway-bridge/" version=3.12.0
WARN[0000] [store] memorystore wiped module=mqtt
INFO[0000] integration/mqtt: connected to mqtt broker
INFO[0000] backend/basicstation: starting websocket listener bind="[::]:3001" ca_cert=/etc/chirpstack-gateway-bridge/ChirpstackCA.crt tls_cert=/etc/chirpstack-gateway-bridge/ChirpstackGatewayBridge.pem tls_key=/etc/chirpstack-gateway-bridge/ChirpstackGatewayBridge.pem
INFO[0007] backend/basicstation: router-info request received gateway_id=xxxx411da4f4xxxx remote_addr="xxx.176.32.xx:14810" router_uri="wss://3.xxx.18.xxx:3001/gateway/xxxx411da4f4xxxx"
INFO[0010] backend/basicstation: gateway connected gateway_id=xxxx411da4f4xxxx remote_addr="xxx.176.32.xx:14810"
INFO[0010] integration/mqtt: subscribing to topic qos=0 topic="gateway/xxxx411da4f4xxxx/command/#"
INFO[0010] integration/mqtt: publishing state gateway_id=xxxx411da4f4xxxx qos=0 state=conn topic=gateway/xxxx411da4f4xxxx/state/conn
ERRO[0010] [client] Connect comms goroutine - error triggered EOF module=mqtt
ERRO[0010] mqtt: connection error error=EOF
INFO[0010] integration/mqtt: connected to mqtt broker
INFO[0010] backend/basicstation: gateway version received firmware= gateway_id=xxxx411da4f4xxxx model=linux package= protocol=2 station=2.0.5
INFO[0010] backend/basicstation: router-config message sent to gateway gateway_id=xxxx411da4f4xxxx
INFO[0011] integration/mqtt: publishing state gateway_id=xxxx411da4f4xxxx qos=0 state=conn topic=gateway/xxxx411da4f4xxxx/state/conn
ERRO[0011] [client] Connect comms goroutine - error triggered EOF module=mqtt
ERRO[0011] mqtt: connection error error=EOF
INFO[0011] integration/mqtt: connected to mqtt broker
INFO[0011] integration/mqtt: subscribing to topic qos=0 topic="gateway/xxxx411da4f4xxxx/command/#"
The mqtt host is aws iot via ssl but the error does not occur when I’m connecting it to my local mqtt broker over tcp.
Along with this error, join accepts can’t reach the gateway bridge.
I’ve managed to get over all of this by using chirpstack gateway bridge 3.10.0, before the conn topic got introduced.
Does anyone have any idea as to why this happens? The logs came from 3.12.0 by the way
