So I am trying to connect a Cisco Gateway to my chirpstack server running in the cloud. I am reasonably happy with the cloud based chirpstack install now and happily have a Raspberry Pi Zero which runs chirpstack-gateway-os-base and connects to my chirpstack network server and Chirpstack application server in the cloud.
So I have read through the following: Cisco - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server and I have updated the software to Cisco LoRaWAN Gateway Software, Version 2.2.0. In the instructions above I have also configured the common packet forwarder profile
common-packet-forwarder profile
ipaddr 192.168.1.6 port 1700
gps enable
antenna 1 omni gain 4.3 loss 0.1
gatewayid 00cebefffeabab01
cpf enable
exit
My understanding is that this forwarder profile must point to a chirpstack gateway bridge. So at 192.168.1.6 I am running Linux and have installed the chirpstack gateway bridge. If it is helpful, I have posted my config file at the end of this post, it is adapted for the AU915 band. Note I actually had to comment out some frequencies for now to get it to run without complaining about frequencies and bandwidth. I will have to return to that issue later.
At the moment, it appears that the chirpstack gateway bridge connects to my cloud based network server and application server. So I can do a sudo systemctl restart chirpstack-gateway-bridge.service and I see a successful reconnect at my cloud based network server and application server.
I think that what I need to debug next is the connection between the cisco common packet forwarder profile and my Linux chirpstack gateway bridge. To debug the Linux chirpstack gateway bridge running locally I can use:
journalctl -u chirpstack-gateway-bridge -f -n 50
But I cannot see anything that looks like it is coming from the Cisco Gateway. Am I approaching this problem in the correct way. Have I overlooked anything?
Thanks for your time,
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
[general]
log_level=5
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=true
[backend]
# Backend type.
type="basic_station"
# Basic Station backend.
[backend.basic_station]
# ip:port to bind the Websocket listener to.
bind=":3001"
# Region.
region="AU915"
# Minimal frequency (Hz).
#frequency_min=916000000
# Maximum frequency (Hz).
#frequency_max=919000000
# Concentrator configuration.
# Note: this is defined twice as the Cisco gateway has two SX1301 chips.
[[backend.basic_station.concentrators]]
# Multi-SF channel configuration.
[backend.basic_station.concentrators.multi_sf]
# Frequencies (Hz).
frequencies=[
916800000,
917000000,
912000000,
917400000,
917600000,
#917800000,
#918000000,
#918200000,
# LoRa STD channel.
[backend.basic_station.concentrators.lora_std]
# Frequency (Hz).
frequency=917500000
# Bandwidth (Hz).
bandwidth=500000
# Spreading factor.
spreading_factor=8
# FSK channel.
#[backend.basic_station.concentrators.fsk]
# Frequency (Hz).
#frequency=918200000
# Frequencies (Hz).
frequencies=[
916800000,
917000000,
917200000,
917400000,
917600000,
#917800000,
#918000000,
#918200000,
# LoRa STD channel.
# Frequency (Hz).
frequency=917500000
# Bandwidth (Hz).
bandwidth=500000
# Spreading factor.
spreading_factor=8
# FSK channel.
# Frequency (Hz).
# Integration configuration.
[integration]
# Payload marshaler.
marshaler="protobuf"
# MQTT authentication.
[integration.mqtt.auth]
type="generic"
# Generic MQTT authentication.
# MQTT servers.
# Configure one or multiple MQTT server to connect to. Each item must be in
# the following format: scheme://host:port where scheme is tcp, ssl or ws.
servers=[
"tcp://chirpstack.runninginthecloud.com:1883",
