Hello!
I installed ChirpStack server in a ubuntu virtual machine.
I created a gateway on the LoRa server with the EUI of the Laird RG1xx gateway.
In the gateway portal I made the Semtech Forwarder configuration. In the network address I put 0.0.0.0 and ports 1700. I used these values because they are the ones that are present in the .toml.
The gateway does not connect to the server, so I believe the problem is the network address.
I have not tested MQTT as the gateway does not have this functionality.
Thank you very much in advance.
