I am new to LoRa technology. I have rhf0m301 gateway with mkr1300 and draguino nodes. I want to send data from the nodes to my gateway and then from my gateway to my own website without connecting to the things network, or loriot.
By installing LoRa gateway OS to my gateway will I be able to achieve that? and if not what will the best way to do?
Hello mathewg,
That is absolutely possible. When you say you are using a “rhf0m301 gateway”, are you using a raspi with it?
You can run LoRaServer on your own server and configure the gateway to communicate with your server directly. More details here: https://www.loraserver.io/overview/
Thanks for your reply. I will work on it.
Hey @zuyang,
Thanks for your solution
