Thanks for your direction but I am still having issues in getting Chirpstack to send application topics to my external broker.
When I modify chirpstack.toml (see below) Chirpstack does not appear to make a connection to my external broker, I have checked the chirpstack and mosquitto logs but can see no error message. I have shown below the chirpstack.toml log showing when a client join request is made to see if this sheds any light on the problem.
If I modify the chirpstack-gateway-bridge.toml with my mqtt credentials I do see and receive published topics.
I am obviously doing something wrong, your help really appreciated.
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@localhost/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://localhost/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"as923",
"as923_2",
"as923_3",
"as923_4",
"au915_0",
"cn470_10",
"cn779",
"eu433",
"eu868",
"in865",
"ism2400",
"kr920",
"ru864",
"us915_0",
"us915_1",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="mysecret"
# Global integration related configuration.
[integration]
# Enabled integrations (global).
enabled = [
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic="application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"
# Command topic.
# This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
command_topic="application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"
# Use JSON encoding instead of Protobuf (binary).
json=true
server="tcp://192.168.1.33:1883/"
username="uuuuu"
password="ppppp"
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# broker. A client id must be no longer than 23 characters. If left blank,
# a random id will be generated by ChirpStack.
client_id=""
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
Chirpstack.toml log
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.291333Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/up" qos=0 json=true
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.493809Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}: chirpstack::uplink: Uplink received m_type="JoinRequest"
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.500067Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::device_keys: Device-nonce validated and stored dev_eui=a84041127184582b dev_nonce=56553
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.502374Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::device_keys: Device-keys updated dev_eui=a84041127184582b
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.502977Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.503442Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::device_queue: Device queue flushed dev_eui=a84041127184582b count=0
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.505671Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::device: Enabled class updated dev_eui=a84041127184582b enabled_class=A
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.506053Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::gateway::backend::mqtt: Sending downlink frame gateway_id=ac1f09fffe0b8059 topic=eu868/gateway/ac1f09fffe0b8059/command/down json=true
Nov 24 15:48:15 chirpstack chirpstack[629]: 2022-11-24T15:48:15.506501Z INFO up{deduplication_id=b4d06043-75c8-49d1-805b-1e2ba6eb76ec}:join_request: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=666988886
Nov 24 15:48:20 chirpstack chirpstack[629]: 2022-11-24T15:48:20.296523Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/ack" qos=0 json=true
Nov 24 15:48:20 chirpstack chirpstack[629]: 2022-11-24T15:48:20.297122Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for gateway gateway_id=ac1f09fffe0b8059
Nov 24 15:48:20 chirpstack chirpstack[629]: 2022-11-24T15:48:20.297429Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for device device_eui=a84041127184582b
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.398928Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/up" qos=0 json=true
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.601224Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}: chirpstack::uplink: Uplink received m_type="UnconfirmedDataUp"
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.602897Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.604811Z INFO chirpstack::storage::device: Setting device lock dev_eui=a84041127184582b
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.609956Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=a84041127184582b dr=0
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.610525Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::maccommand::device_time: DeviceTimeReq received dev_eui=a84041127184582b rx_time=2022-11-24 15:48:22.316859 UTC gps_time=1353340120
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.610932Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=a84041127184582b
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.616106Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.616469Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=HOUR
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.616692Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=DAY
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.616925Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=MONTH
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.617617Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::mac_command: Pending mac-command block set dev_eui=a84041127184582b cid=LinkADRReq
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.618035Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=2877018956
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.618293Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:22 chirpstack chirpstack[629]: 2022-11-24T15:48:22.618434Z INFO up{deduplication_id=6cdbe526-c222-439a-89d8-8a2a269b5881}:data_up: chirpstack::gateway::backend::mqtt: Sending downlink frame gateway_id=ac1f09fffe0b8059 topic=eu868/gateway/ac1f09fffe0b8059/command/down json=true
Nov 24 15:48:23 chirpstack chirpstack[629]: 2022-11-24T15:48:23.400451Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/ack" qos=0 json=true
Nov 24 15:48:23 chirpstack chirpstack[629]: 2022-11-24T15:48:23.401260Z INFO chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:23 chirpstack chirpstack[629]: 2022-11-24T15:48:23.401430Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for gateway gateway_id=ac1f09fffe0b8059
Nov 24 15:48:23 chirpstack chirpstack[629]: 2022-11-24T15:48:23.401685Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for device device_eui=a84041127184582b
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.102145Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/up" qos=0 json=true
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.304334Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}: chirpstack::uplink: Uplink received m_type="UnconfirmedDataUp"
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.306404Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.307221Z INFO chirpstack::storage::device: Setting device lock dev_eui=a84041127184582b
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.309486Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device: Data-rate updated dev_eui=a84041127184582b dr=5
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.310221Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::mac_command: Pending mac-command block deleted dev_eui=a84041127184582b cid=LinkADRAns
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.310446Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::maccommand::link_adr: LinkADRReq acknowledged dev_eui=a84041127184582b tx_power_index=2 dr=5 nb_trans=1 enabled_channels=[0, 1, 2, 3, 4, 5, 6, 7]
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.310646Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::maccommand::dev_status: DevStatusAns received dev_eui=a84041127184582b battery=100 margin=4
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.314978Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device: Device status updated dev_eui=a84041127184582b
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.315752Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device_gateway: Gateway rx-info saved dev_eui=a84041127184582b
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.320515Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.320934Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=HOUR
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.321167Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=DAY
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.321419Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::metrics: Metrics saved name=device:a84041127184582b aggregation=MONTH
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.321851Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::mac_command: Pending mac-command block set dev_eui=a84041127184582b cid=LinkADRReq
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.322059Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=25356217
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.322337Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:25 chirpstack chirpstack[629]: 2022-11-24T15:48:25.322464Z INFO up{deduplication_id=5060ae15-00ba-445c-ac6f-6fa45b4f07b0}:data_up: chirpstack::gateway::backend::mqtt: Sending downlink frame gateway_id=ac1f09fffe0b8059 topic=eu868/gateway/ac1f09fffe0b8059/command/down json=true
Nov 24 15:48:27 chirpstack chirpstack[629]: 2022-11-24T15:48:27.104201Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/ack" qos=0 json=true
Nov 24 15:48:27 chirpstack chirpstack[629]: 2022-11-24T15:48:27.104917Z INFO chirpstack::storage::device_session: Device-session saved dev_eui=a84041127184582b dev_addr=0154116d
Nov 24 15:48:27 chirpstack chirpstack[629]: 2022-11-24T15:48:27.105018Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for gateway gateway_id=ac1f09fffe0b8059
Nov 24 15:48:27 chirpstack chirpstack[629]: 2022-11-24T15:48:27.105303Z INFO chirpstack::downlink::tx_ack: Log downlink-frame for device device_eui=a84041127184582b
Nov 24 15:48:31 chirpstack chirpstack[629]: 2022-11-24T15:48:31.308380Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_name="eu868" topic="eu868/gateway/ac1f09fffe0b8059/event/stats" qos=0 json=true
Nov 24 15:48:31 chirpstack chirpstack[629]: 2022-11-24T15:48:31.311100Z INFO stats{gateway_id=ac1f09fffe0b8059}: chirpstack::storage::gateway: Gateway state updated gateway_id=ac1f09fffe0b8059
Nov 24 15:
