Dear community,
I’m trying to connect my Chirpstack Gateway Bridge to Google Cloud Platform using the following guide:
However, when I start the gateway bridge on my gateway device I receive the following output (debug level):
INFO[0000] starting ChirpStack Gateway Bridge docs="https://www.chirpstack.io/gateway-bridge/" version=3.13.2
INFO[0000] backend/semtechudp: starting gateway udp listener addr="127.0.0.1:8001"
DEBU[0000] backend/semtechudp: cleanup gateway registry
DEBU[0003] [client] Connect() module=mqtt
DEBU[0003] [store] memorystore initialized module=mqtt
DEBU[0003] [client] about to write new connect msg module=mqtt
DEBU[0003] [client] socket connected to broker module=mqtt
DEBU[0003] [client] Using MQTT 3.1.1 protocol module=mqtt
DEBU[0003] [net] connect started module=mqtt
ERRO[0003] [net] connect got error EOF module=mqtt
ERRO[0003] [client] Connecting to ssl://mqtt.googleapis.com:8883 CONNACK was not CONN_ACCEPTED, but rather Connection Error module=mqtt
ERRO[0003] [client] Failed to connect to a broker module=mqtt
DEBU[0003] [store] memorystore closed module=mqtt
ERRO[0003] integration/mqtt: connection error error="network Error : EOF"
I’m using the following MQTT Authentication settings:
[integration.mqtt.auth.gcp_cloud_iot_core]
server=“ssl://mqtt.googleapis.com:8883”
device_id=“gw-45…001”
project_id="…"
cloud_region=“europe-west1”
registry_id="…"
jwt_key_file="/home/root/chirpstack/private-key.pem"
This matched my Google IoT settings.
I’m using chirpstack gateway bridge on armv7.
I tried to install gateway bridge from apt on my debian install, and I got the same error.
Is there something that I’m missing? Could someone help me out? Thanks!
