Current I am building a LoRa server with CISCO gateway, model IXM-LPWA-900-16-K9.
Everything was fine until it comes to the part of issuing rx packet(I supposed, after reading other posts) from the bridge to server.
As show below, the process got stuck in the loop of pullACK → pullData → pushACK → pushData → received stats:
June 19 15:06:04 kuro-VirtualBox systemd[1]: Stopped LoRa Gateway Bridge. June 19 15:06:04 kuro-VirtualBox systemd[1]: Started LoRa Gateway Bridge. June 19 15:06:04 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:06:04+08:00" level=info msg="starting LoRa Gateway Bridge" docs="ht__tps://www.loraserver.io/lora-gateway-bridge/" version=2.4.1 June 19 15:06:04 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:06:04+08:00" level=info msg="backend: TLS config is empty" June 19 15:06:04 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:06:04+08:00" level=info msg="backend: connecting to mqtt broker" server="tcp://127.0.0.1:1883" June 19 15:06:04 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:06:04+08:00" level=info msg="gateway: starting gateway udp listener" addr="0.0.0.0:1700" June 19 15:06:04 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:06:04+08:00" level=info msg="backend: connected to mqtt broker" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:07:16+08:00" level=info msg="signal received" signal=terminated June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:07:16+08:00" level=warning msg="shutting down server" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:07:16+08:00" level=info msg="gateway: closing gateway backend" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30095]: time="2018-06-19T15:07:16+08:00" level=info msg="gateway: handling last packets" June 19 15:07:16 kuro-VirtualBox systemd[1]: Stopping LoRa Gateway Bridge... June 19 15:07:16 kuro-VirtualBox systemd[1]: Stopped LoRa Gateway Bridge. June 19 15:07:16 kuro-VirtualBox systemd[1]: Started LoRa Gateway Bridge. June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:07:16+08:00" level=info msg="starting LoRa Gateway Bridge" docs="ht__tps://www.loraserver.io/lora-gateway-bridge/" version=2.4.1 June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:07:16+08:00" level=info msg="backend: TLS config is empty" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:07:16+08:00" level=info msg="backend: connecting to mqtt broker" server="tcp://127.0.0.1:1883" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:07:16+08:00" level=info msg="gateway: starting gateway udp listener" addr="0.0.0.0:1700" June 19 15:07:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:07:16+08:00" level=info msg="backend: connected to mqtt broker" June 19 15:09:22 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:22+08:00" level=info msg="gateway: received udp packet from gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullData June 19 15:09:22 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:22+08:00" level=info msg="backend: subscribing to topic" qos=0 topic=gateway/000070d3798e04b8/tx June 19 15:09:22 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:22+08:00" level=info msg="backend: subscribing to topic" qos=0 topic=gateway/000070d3798e04b8/config June 19 15:09:22 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:22+08:00" level=info msg="gateway: sending udp packet to gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullACK June 19 15:09:31 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:31+08:00" level=info msg="gateway: received udp packet from gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullData June 19 15:09:31 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:31+08:00" level=info msg="gateway: sending udp packet to gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullACK June 19 15:09:41 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:41+08:00" level=info msg="gateway: received udp packet from gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullData June 19 15:09:41 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:41+08:00" level=info msg="gateway: sending udp packet to gateway" addr="192.168.1.3:40302" protocol_version=2 type=PullACK June 19 15:09:42 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:42+08:00" level=info msg="gateway: received udp packet from gateway" addr="192.168.1.3:48913" protocol_version=2 type=PushData June 19 15:09:42 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:42+08:00" level=info msg="gateway: stat packet received" addr="192.168.1.3:48913" mac=000070d3798e04b8 June 19 15:09:42 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:42+08:00" level=info msg="backend: publishing packet" qos=0 topic=gateway/000070d3798e04b8/stats June 19 15:09:42 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:42+08:00" level=info msg="gateway: sending udp packet to gateway" addr="192.168.1.3:48913" protocol_version=2 type=PushACK June 19 15:09:47 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:47+08:00" level=info msg="gateway: received udp packet from gateway" addr="192.168.1.3:48913" protocol_version=2 type=PushData June 19 15:09:47 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:47+08:00" level=info msg="gateway: stat packet received" addr="192.168.1.3:48913" mac=000070d3798e04b8 June 19 15:09:47 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:47+08:00" level=info msg="backend: publishing packet" qos=0 topic=gateway/000070d3798e04b8/stats June 19 15:09:47 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:09:47+08:00" level=info msg="gateway: sending udp packet to gateway" addr="192.168.1.3:48913" protocol_version=2 type=PushACK June 19 15:11:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:11:16+08:00" level=info msg="backend: unsubscribing from topic" topic=gateway/000070d3798e04b8/tx June 19 15:11:16 kuro-VirtualBox lora-gateway-bridge[30123]: time="2018-06-19T15:11:16+08:00" level=info msg="backend: unsubscribing from topic" topic=gateway/000070d3798e04b8/config
FYI, below is the log for loraserver:
June 19 15:06:40 kuro-VirtualBox systemd[1]: Stopped LoRa Server. June 19 15:06:40 kuro-VirtualBox systemd[1]: Started LoRa Server. June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="starting LoRa Server" band=AS_923 docs="https://docs.loraserver.io/" net_id=000000 version=1.0.0 June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="setup redis connection pool" url="redis://localhost:6379" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="connecting to postgresql" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="backend/gateway: TLS config is empty" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="backend/gateway: connecting to mqtt broker" server="tcp://localhost:1883" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="configuring join-server client" ca_cert= server="http://localhost:8003" tls_cert= tls_key= June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="no network-controller configured" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="applying database migrations" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="backend/gateway: connected to mqtt server" June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="backend/gateway: subscribing to rx topic" qos=0 topic=gateway/+/rx June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="backend/gateway: subscribing to stats topic" qos=0 topic=gateway/+/stats June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="migrations applied" count=0 June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="starting api server" bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key= June 19 15:06:40 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:06:40+08:00" level=info msg="starting downlink device-queue scheduler" June 19 15:09:42 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:09:42+08:00" level=info msg="backend/gateway: gateway stats packet received" mac=000070d3798e04b8 June 19 15:09:42 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:09:42+08:00" level=info msg="gateway updated" mac=000070d3798e04b8 June 19 15:09:47 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:09:47+08:00" level=info msg="backend/gateway: gateway stats packet received" mac=000070d3798e04b8 June 19 15:09:47 kuro-VirtualBox loraserver[30111]: time="2018-06-19T15:09:47+08:00" level=info msg="gateway updated" mac=000070d3798e04b8
Please suggest what can I do!! Thanks.
Remark: I am running Ubuntu 18.04 on VirtualBox.
