Convert dates | decoding an pplink (after a downlink) | BMeter IWM LR3/4
From this manual: https://www.bmeters.com/wp-content/uploads/2021/07/v1.0_IWM-LR3_LR4_UM_EN.pdf
I’ve done a downlink to get alarm data (3.11 in the manual, page 19), The downlink command is: 280000000104
The uplink i’ve received are as follows (several BMeters)
Header            01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
28 01 00 00 1D 04 00 00 00 00 00 00 00 00 10 05 17 00 00 00 00 00 14 05 12 00 18 05 17 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 00 00 00 00 00 18 09 18 00 00 00 00 00 05 09 18 00 00 00 00 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 16 09 18 00 00 00 00 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 1A 09 18 00 19 07 17 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 12 00 00 00 00 04 05 12 00 00 00 00 00 07 09 18 00 02 06 17 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 08 00 00 00 00 18 09 18 00 00 00 00 00 1C 09 18 00 00 00 00 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 00 00 00 00 00 0F 05 17 00 00 00 00 00 1B 09 18 00 00 00 00 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 02 00 00 00 00 0F 05 17 00 00 00 00 00 1D 07 18 00 00 00 00 00 00 00 00 00
28 01 00 00 1D 04 00 00 00 12 00 00 00 00 1A 02 18 00 00 00 00 00 17 07 18 00 03 04 18 00 00 00 00 00
Now when I’m trying to convert the dates, I’m not getting the correct ones. For example
  • 00 00 00 12 (hex) = (bin) 00010010
  • 00 00 00 00 (hex) = (dec) 0
  • 04 05 12 00 (hex) = (dec) 67441152
  • 07 09 18 00 (hex) = (dec) 118036480
  • 02 06 17 00 (hex) = (dec) 33953536
Now when converting epoch to human-readable date, I’m now getting the correct dates (should be year 2024 at least).
Epoch 67441152 = Sunday, February 20, 1972 1:39:12 PM (GMT)
Epoch 118036480 = Friday, September 28, 1973 3:54:40 AM (GMT)
Epoch 33953536 = Thursday, January 28, 1971 11:32:16 PM (GMT)
What did I do wrong? Or the BMeter is sending wrong uplink? What are the solutions here?
Thanks,
Nadim
In page 11, do you need to set the date and time for this node?
In this codec for uplink, it seems no datetime in the uplink in the decoder.
No. This downlink (0x14) will be deprecated (according to the vendor), because it’s difficult to set the correct time (the downlink is not executed immediately after it is sent)
When you are installing this device on a mechanical meter, you set the date/time and also some other parameters (initial meter reading, k-index, etc) via a mobile app which uses NFC - so manually you set date/time.
