This is what I experienced:
- I ran
docker-compose run --rm loraserver bash - The container builds for the first time, seems that everything in the dockerfile is executed.
2.1 There is no/buildfolder in path the shell spawned in.
From here I don’t really understand what’s going on. This is how I continued:
- I used the make commands, and then run the executable in the
/buildfolder.
The main questions: Is this the correct way? I think it’s weird mainly because I see in the output the first time I run docker-compose run --rm loraserver bash that the Dockerfile is executed (which contains the make arguments).
Second questions: I specified the - port value in the docker-compose file, but I still can’t access the GUI via https://localhost:8080
Thanks in advanced.
