Could not get Gateway ID from backend, error: Gateway ID not yet set
I am using the chirpstack-mqtt-forwarder 4.1.3 on a kerlik iBTs with kerOS 5.10.1.
Using the TRACE log level, I get this message error :
As far as I am concerned, the Gateway ID is stored on the gateway itself. Ho to configure chirpstack MQTT forwarder to get this Gateway ID ?
Thanks
Nop Microwave
The ChirpStack MQTT Forwarder receives the Gateway ID from the Semtech UDP Packet Forwarder or compatible implementation (as Kerlink has their own implementation).
This error means that something tries to read the Gateway ID, but that no UDP frame containing the Gateway ID was received yet. This might happen when you just started the MQTT Forwarder. E.g. it might take a few seconds before it received the Gateway ID.
