Hi, hoping someone can get me on the right track here. ![]()
I’ve a Raspberry Pi 3B+ and PiSupply (RAK2247) Hat. I’ve set up the Gateway OS (4.2.0 Full) and configured Concentratored to SX1301 as below:
I can’t however seem to get it to show the Gateway ID in the footer - I get “Gateway ID: could not read gateway_id”.
I’m assuming the concentrator is not starting properly and the logs appear to show a loop:
Thu Jan 4 17:46:49 2024 user.info chirpstack-concentratord-sx1301[4061]: Starting the concentrator Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Triggering sx1302 reset Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting up concentrator radios Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting up concentrator channels Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Starting the concentrator Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Triggering sx1302 reset Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting up concentrator radios Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting up concentrator channels Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Starting the concentrator Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Triggering sx1302 reset Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting up concentrator radios Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting up concentrator channels Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Starting the concentrator Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Triggering sx1302 reset Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting up concentrator radios Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting up concentrator channels Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Starting the concentrator Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Triggering sx1302 reset Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting up concentrator radios Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting up concentrator channels Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Two things strike me.
- It references “Triggering sx1302 reset”, but should this not be “sx1301” ?
- Also there is reference to “Configuring reset pin, dev: /dev/gpiochip0, pin: 22” and I’ve seen some posts about the RAK2247 that says this should be pin 17 - I think though that this is if you are not using the pisupply hat.
The only other thing that might be relevent is that I’m using the Pisupply ip67 hat holder (Nebra IP67 Case - Gateway HAT Mounting & Raspberry Pi Expansion Board — Pi Supply) with the RAK2247 hat in location 3
Hopefully someone can point me in the right direction …
