Hi!
I have the following error when I try to go to device activation via the GUI:
(request URL: https://xx.xx.xx.xx:8080/api/devices/0101010101010101/activation)
{“error”:“object does not exist”,“code”:5}
The error message in the app-server log:
time=“2018-04-17T10:38:55Z” level=info msg=“finished unary call with code NotFound” error=“rpc error: code = NotFound desc = object does not exist” grpc.code=NotFound grpc.method=GetActivation grpc.service=api.Device grpc.start_time=“2018-04-17T10:38:55Z” grpc.time_ms=9.532 peer.address=“127.0.0.1:45272” span.kind=server system=grpc
The statement before that was executed:
time=“2018-04-17T10:38:55Z” level=debug msg=“sql query executed” args="[[1 1 1 1 1 1 1 1]]" duration=2.107424ms query="\n select *\n from device_activation\n where\n dev_eui = $1\n order by\n created_at desc\n limit 1"
The database:
dev_eui | created_at | updated_a | application_id | device_profile_id | name | desiption | last_seen_at | device_status_battery | device_status_margin
\x0101010101010101 | 2018-04-17 10:37:05.209145+00 | 2018-04-17 10:37:05.209145
+00 | 1 | 6089487c-8a7e-41f3-a987-315c14ba2973 | dev-3 | dev-3
It seems that the error code comes from this SQL stmt, could this be the case?. But is it really[1 1 1 1 1 1 1 1]
that is used as argument and not \x0101010101010101
? Seems like it’s obvious this would return zero results because of the different formats of the two values.
