Dear all,
I am interfacing the LoRa App Server with a C++ program using gRPC. So far, I have successfully managed to do authentication and create all the bits and pieces needed for a basic setup like an organization, application, service profile, device, profile, etc., through gRPC calls.
Now I am working on the device creation/deletion interface. Here I noticed then when I create a device and then afterwards the device keys, the “Application Key” always gets sets to all zeros even though I am not setting it the corresponding field in the DeviceKeys proto message. Since I am using 1.0 devices and the UI says that I should leave the field blank, I was wondering if this is a problem and, if so, how I can send the CreateDeviceKeys request without setting the “Application Key”.
Thank you for your help!
Best, Levent
PS: I am using LoRa App Server 2.0, LoRa Server 2.0 and Gateway Bridge 2.4.1
