What would be right way to add series of nodes in App Server.
I have to add 100 nodes and have name, DEVEUI, APEUI and APKKEY.
Is there a way that I do not need to enter each node individually?
I see that there is api for creating node
post /api/nodes
How can I run this api - not using web interface?
That way I could automatize it.
Ok I saw it when I have tried to use it it is using curl. I will use that in console.
ok here is script how to do one from command line
put it in some script file and modify it I do not need all data
#!/bin/bash
# curl yourNodeName yourAppKey yourDevEUI
# or add more parameters
curl --insecure -X POST --header 'Content-Type: application/json' --header 'Accept: application/json' --header 'Grpc-Metadata-Authorization: yourYWTtoken' -d "{
\"adrInterval\": 0,
\"appEUI\": \"yourappEUI\",
\"appKey\": \"$2\",
\"applicationID\": \"7\",
\"description\": \"yourDescription\",
\"devEUI\": \"$3\",
\"installationMargin\": 0,
\"isABP\": false,
\"isClassC\": false,
\"name\": \"$1\",
\"relaxFCnt\": true,
\"rx1DROffset\": 0,
\"rx2DR\": 0,
\"rxDelay\": 0,
\"rxWindow\": \"RX1\",
\"useApplicationSettings\": true
}" 'https://yourWEB:8080/api/nodes'
