Hi !
I have the same issue, reset pin is 5 but need to change to 25, I have a shield board between the rapi 3 and ic 880A, apparently the file to change is /dev/gpiochi0 but i dont know how to change on openwrt, then it enters in a loop of restart :
Fri Feb 16 22:50:56 2024 user.info chirpstack-concentratord-sx1301[2240]: Starting the concentrator
Fri Feb 16 22:50:59 2024 cron.err crond[975]: time disparity of 108 minutes detected
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring reset pin, dev: /dev/gpiochip0, pin: 5
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Starting Concentratord SX1301 (version: 4.3.5, docs: Introduction - ChirpStack open-source LoRaWAN® Network Server documentation)
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Triggering sx1302 reset
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Setting spi device path, spidev_path: /dev/spidev0.0
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Setting board configuration, lorawan_public: true, clock_source: 1
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Setting up concentrator radios
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Setting up concentrator channels
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Fri Feb 16 22:51:01 2024 user.info chirpstack-concentratord-sx1301[2264]: Starting the concentrator
