I would like to start to implement my own ADR Algorithm (using metrics that are not provided to LoRaServer).
Any idea about a start point ?
As a first thing, I will have to disable LoRa Server ADR : how to proceed ?
Then I have to find gRPC modules that I can use to use my own ADR : is there documentation on ADR architecture some where ?
Thanks,
Nop
You can implement the network-controller interface https://github.com/brocaar/loraserver/blob/master/api/nc/nc.proto to receive uplink mac-commands and meta-data. For downlink mac-commands you can call this method: https://github.com/brocaar/loraserver/blob/master/api/ns/ns.proto#L87.
@brocaar
Thanks a lot for these information. How can I disable LoRaSERVER ADR to disable its mac-commands ?
I do not want 2 ADR MAC commands to be sent simultneously.
Nicolas
Please see the loraserver.toml
configuration file
I have just read loraserver.toml
The only section that deals with dr is :
frequency=867100000
min_dr=0
max_dr=5
So I guess that I have to set min_dr and max_dr for all frequencies to the same value ?
That’s correct ?
Nop Micro
I think he means these parameters:
# Disable mac-commands
# When set to true, LoRa Server will not handle and / or schedule any
# mac-commands. However, it is still possible for an external controller
# to handle and / or schedule mac-commands. This is intended for testing
# only.
disable_mac_commands=false
# Disable ADR
# When set, this globally disables ADR.
disable_adr=false
I am back …
I still looking for information to call a MACCommandQueue using a Pyhon client.
I do not know how to start. I guess that LoRaServer gRPC server is listening on localhost:PORT.
What is PORT ?
Is ther any snippet code in python somewhere ?
I will then have to call this method :
rpc CreateMACCommandQueueItem(CreateMACCommandQueueItemRequest) returns (google.protobuf.Empty) {}
Thanks,
Nop
