Im trying to get downlinks’ MacCommands in Application Server and write them to the loradatastore db which has no downlink table(but it has uplink table named “device_up”). Because I want to track MacCommands, which the Downlinks has it in, that is sending from Network Server to the Gateway.
However, as I recognized, there is no related function in application server to handle downlink payload. I can see downlinks’ maccommands in the application server’s UI but I want to handle this data when the UI is not running.
I forked your source codes from your github repositories. I can access Downlinks’ MacCommands in Network Server, I think I should send these to AS. In AS, I try to add a controller to the as.go named HandleDownlinkData(like HandleUplinkData) but in this case I should add new structs related downlink to the API’s readonly files(like as.pb.go). I guess this is not a best practice for this work.
What would you suggest to me in this case ?
Thanks.
