How customisable is the LoRa Gateway OS?
I’ve just set up a Lorix One on our network and it is working quite nicely but would like to deploy them off our network. I don’t want to go via an external IP so would like to add in an OpenVPN connection.
Would this be a case of installing the .deb package or be more involved?
T
Please see https://github.com/brocaar/lora-gateway-os/, you will need that to compile additional packages. I also recommend to get yourself familiar with Yocto: https://www.yoctoproject.org/.
However, what you want to do might already be provided by the image
Note that the image already include a Wireguard VPN client, which has a lower footprint than OpenVPN and is easier to configure.
Brilliant, thanks for the reply. I’ll look in to Wiregard VPN…we already use OpenVPN but could NAT straight to the server.
Cant get Wireguard working on the gateway.
I’ve changed /etc/default/wireguard to Disabled=“no”
/etc/init.d/wireguard start produces:
Starting wireguard
[#] ip link add wg0 type wireguard
RTNETLINK answers: Operation not supported
Unable to get device: Protocol not supported
dmesg shows:
wireguard: Unknown symbol udp_tunnel_sock_release (err 0)
wireguard: Unknown symbol setup_udp_tunnel_sock (err 0)
wireguard: Unknown symbol udp_sock_create6 (err 0)
wireguard: Unknown symbol udp_tunnel_xmit_skb (err 0)
lsmod | grep wire shows nothing
Tried:
#modprobe udp_tunnel
modprobe: FATAL: Module udp_tunnel not found in directory /lib/modules/4.4.68-01691-ga1184ff5f29f
#modprobe wireguard
modprobe: ERROR: could not insert ‘wireguard’: Unknown symbol in module, or unknown parameter (see dmesg)
modinfo wireguard
filename: /lib/modules/4.4.68-01691-ga1184ff5f29f/kernel/wireguard/wireguard.ko
alias: net-pf-16-proto-16-family-wireguard
alias: rtnl-link-wireguard
version: 0.0.20171221
author: Jason A. Donenfeld Jason@zx2c4.com
description: Fast, secure, and modern VPN tunnel
license: GPL v2
srcversion: 04ADBD36B4D881DBCF97AD0
depends:
vermagic: 4.4.68-01691-ga1184ff5f29f mod_unload ARMv7 p2v8
Any clues as to what you are doing differently?
Hi Brocaar,
I’ve tried various versions from https://artifacts.loraserver.io/downloads/lora-gateway-os/wifx/sama5d4-lorix-one-512-sd/ but get the same issue with all of them.
What am I not understanding?
I’m trying to understand how to customize lora gateway os and I’m also new on yoctoproject.
I followed the steps presented here https://github.com/brocaar/chirpstack-gateway-os in order to build an image and I stopped at the line “make submodules”, which showed:
git submodule init
git submodule update
Cloning into ‘/opt/chirpstack-gateway-os/docs/themes/chirpstack-hugo-theme’…
git@github.com: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
fatal: clone of ‘git@github.com:brocaar/chirpstack-hugo-theme.git’ into submodule path ‘/opt/chirpstack-gateway-os/docs/themes/chirpstack-hugo-theme’ failed
Failed to clone ‘docs/themes/chirpstack-hugo-theme’. Retry scheduled
Failed to clone ‘docs/themes/chirpstack-hugo-theme’ a second time, aborting
make: *** [Makefile:5: submodules] Error 1
I execute “make submodules” as root and I suppose it’s an easy problem, but how can I solved that ?
It was easy, and I hope this could help some one.
I found out the solution just changing the line “url = git@github.com:brocaar/chirpstack-hugo-theme.git” to “url = https://github.com/brocaar/chirpstack-hugo-theme.git” in the .gitmodules file.
