i’m working with the full image of the gateway-os for pi3.
It appears that the gateway is receiving the packages i send from my device but it doesn’t get forwarded to the application/devices.
Screenshot from a package received in the Gateway tab on the web application.
I also checked the broker. It gives lines like “gateway/-id-/event/up”
When i look into the devices it says “never seen”.
Did i failed any configuration? (using ABP)
Device configurations:
General:
LoRaWAN MAC version: 1.0.0
Regional Parameters revision: A
Max EiRP: 15
Geolocation buffer TTL: 0
Geolocation minimum buffer size: 0
for ABP you need to be sure that following parameters
Device EUI
Device address
Network session key
Application session key
are the same iside the device and device configuration in the ChirpStack UI
I triple checked on that also, everything fits.
I’m using the LMIC library for my devices.
The only thing differing is that i added 0x so that it fits the format for the LMIC.
