Hi all,
i want to write a short java codec function under “Application configuration” which return an object in SenML format for testing purpose, because the IOT platform mainflux requires SenML.
I tried:
return {[“n”:“temperature”,“v”:1.2]};
But this is not working. Who can help me ?
Thanks in advance
Regards
Uli
The syntax is wrong, it should be something like this (no square brackets and correct quote marks):
return {
"n": "temperature",
"v": 1.2
Hi legomez,
but the square brackets are required for the SenML format.
Regards
Uli
Could you share a link to the format definition?
here is the Link to the ietf draft:
https://tools.ietf.org/id/draft-ietf-core-senml-16.txt
Thanks for your support.
Regards
Uli
Ok, so I guess you are forwarding this through the http integration. In this case, the service receiving the data should extract the data from the js object. That is, at lora-app-server you may have something like this:
return {
"SenMLdata" : [
{"n": "temperature", "v": 1.2},
{"n": "temperature", "v": 0.8},
Then at the integration’s end you just need to read object["SenMlData"]
to get your array. This has to be done this way because the Decode function must return a JS object, not an array.
