Decode protobuf into json
Hi everyone
I have two questions about the protobuf event type in ChirpStack.
My lora gateways send events in protobuf (which is what I want) and I want to receive these events in a Node-RED MQTT client.
  • Is there a configuration to auto-decode these events into json, when they arrive on ChirpStack? That would be useful because I’m working with device profile codec’s.
  • If there is no configuration, is there any prebuild Node-RED node for that? I just found the following package: @chirpstack/node-red-contrib-chirpstack - npm
Thanks for your help
There exists JavaScript client code for the ChirpStack protobuf packages here:
It appears that some people are doing protobuf encoding and decoding in Node-RED:
https://www.google.com/search?q=node-red+protobuf
I have not done so and cannot speak to the quality of those options, however. I normally reach for Go and an MQTT library when doing these types of tasks, but there are many ways to skin this cat.
Just so I understand.
These clients are auto-decoding the protobuf events into json?
And can I use them in the device profile codec on the ChirpStack dashboard?
Ok, I will try it out.
I’m not sure if what you are asking for is what you need. By default the Gateway <> ChirpStack communication is Protobuf over MQTT. However, the ChirpStack > Integration events are by default in JSON.
When working with codec functions in the device-profile, it does not matter if the GW <> ChirpStack communication is Protobuf or JSON.
Sorry, what do you mean by Integration events?
From my understanding I can set the event type on the gateway for Gateway <> ChirpStack communication to either Protobuf or JSON.
When I configured a gateway to Protobuf, the uplink event I got in the device-profile was also in Protobuf and same for JSON events. Maybe I just misconfigured something.
That’s why I wanted to decode the Protobuf events into JSON.
https://www.chirpstack.io/docs/chirpstack/integrations/index.html
You might want to revisit the architecture portion of the docs to get a better understanding of ChirpStack-Gateway-Device communication and how that data then leaves ChirpStack.
