I am sending text data from a device. This text is contained in the array from Byte 6. Could anyone help me work out how to decode the array after byte 6 please?
the Base64 is:
AwYABgABMTIzNEtn
The code i use at the moment is:
function Decode(fport, bytes) {
// Decode plain text; for testing only
return {
receivedString: String.fromCharCode.apply(null, bytes)
This obviously returns the full byte string in text form as below:
I am not interested in returning the data from the first 5 bytes as these are stop characters etc. I am only interested in extracting the ‘1234Kg’
Hey thanks for the reply, I am up against a deadline to get this coded and I am struggling to get to an answer quickly, hence so many topics in different forms. The first where about getting the data to show, once i did that they were about ignoring the first four bytes.
So presumably if i did something like that in my decoder, the code would then look something like below?:
var weight.value = bytes[4];
return {
receivedString: String.fromCharCode.apply(null, weight.value)
Thank you for your reply by the way, it has been the most helpful so far. As you will have seen on my other posts, I am new to this and everything is a learning curve for me. I really appreciate you replying!
I tested that and I got this error repeatedly no matter what i seemed to do.
error :"js vm error: TypeError"
It gives me no clue as to what the problem is or how to fix it, that is the only feedback i get.
I am so confused because the raw code i submitted first gives me a string that contains the data i need, I just need to ignore the first few bits but I just can’t figure out how to do it. I know the aim is to give me the direction to head in and let me figure it out but I am in need of a little more guidance if possible?
Thanks you so much for that, it is the kind of help I have been looking for!
I tried the code and I don’t get any errors with that (apart from one because there was a semi-colon at the end of receivedString: String.fromCharCode(value); that didnt need to be there but sorted that.
When i upload data to the server however. I get the result:
receivedString:"";
Any ideas on why that is? I have tried different byte numbers in the argument too and that didnt work either.
