Hi
I have a decoder for my device and when I take the string in the data field under device data and put it in my decoder I get the results that I expect but when I put the code under the device profile under the decoder I get the following error:
- error:“execute js error: js vm error: (anonymous): Line 17:5 Unexpected reserved word (and 1 more errors)”
This is my decoder:
// Decode decodes an array of bytes into an object.
// - fPort contains the LoRaWAN fPort number
// - bytes is an array of bytes, e.g. [225, 230, 255, 0]
// The function must return an object, e.g. {"temperature": 22.5}
function base64ToHex(str) {
var raw = atob(str);
var res = "";
for (var i = 0; i < raw.length; i++) {
var hex = raw.charCodeAt(i).toString(16);
res += (hex.length === 2 ? hex : '0' + hex);
return res.toUpperCase();
function hexStringToFloat(hexStr) {
const hex = parseInt(hexStr, 16);
const sign = hex >> 31 ? -1 : 1;
const exponent = (hex >> 23) & 0xFF;
return sign * (hex & 0x7fffff | 0x800000) * 1.0 / Math.pow(2, 23) * Math.pow(2, (exponent - 127));
var incomingHexData = base64ToHex(bytes);
var deviceSerial = parseInt(incomingHexData.substring(0, 8), 16);
var deviceTotalEnergy = hexStringToFloat(incomingHexData.substring(12, 20));
var deviceVoltage = hexStringToFloat(incomingHexData.substring(20, 28));
var deviceCurrent = hexStringToFloat(incomingHexData.substring(28, 36));
return {
"serialNumber": deviceSerial,
"totalEnergy": deviceTotalEnergy,
"voltage": deviceVoltage,
"current": deviceCurrent
This is a frame:
The data as text:
data:"AU4D/gEUPnS8akNtlH0+W+dYP3tp0UJHzgyb+w=="
Any help appreciated
