Q_Lion
July 9, 2018, 9:15pm
#1
Hi
I’m trying to do a custom decode on a application with devices.
My decode function is as follows.
function base64toHEX(base64) { //// Convert To HEX
var raw = atob(base64);
var HEX = '';
for (i = 0; i < raw.length; i++) {
var _hex = raw.charCodeAt(i).toString(16)
HEX += (_hex.length == 2 ? _hex : '0' + _hex);
return HEX.toUpperCase();
var Hex = base64toHEX(bytes);
var spHex = Hex.split('');
var antiDismantled = spHex[0]+spHex[1];
var Gsensor = spHex[2]+spHex[3];
var charGing = spHex[4]+spHex[5];
var volts = "0x"+spHex[6]+spHex[7];
volts = volts/10;
var latTemp = "0x"+spHex[8]+spHex[9]+spHex[10]+spHex[11]+spHex[12]+spHex[13];
var lngTemp = "0x"+spHex[14]+spHex[15]+spHex[16]+spHex[17]+spHex[18]+spHex[19];
var lat = 0;
var lng = 0;
if(latTemp > 0x7FFFFF) {
lat = - (0x01000000 - latTemp) * 90 / 0x800000;
}else{
lat = (latTemp) * 90 / 0x7FFFFF;
if(lngTemp > 0x7FFFFF) {
lng = - (0x01000000 - lngTemp) * 180 / 0x800000;
}else{
lng = (lngTemp) * 180 / 0x7FFFFF;
return {AntiDismantled:antiDismantled,Gsensor:Gsensor,charGing:charGing,volts:volts,latitude:lat,longitude:lng};
But in the MQTT is only get
application/6/node/70c5a8ffee000020/rx {“applicationID”:“6”,“applicationName”:“Wi360_Tracker”,“deviceName”:“WI360_001”,“devEUI”:“70c5a8ffee000020”,“rxInfo”:[{“mac”:“b827ebfffec0f3de”,“rssi”:-16,“loRaSNR”:7.8,“name”:“RakGW001”,“latitude”:-24.672563155826822,“longitude”:25.938591957092285,“altitude”:0}],“txInfo”:{“frequency”:867700000,“dataRate”:{“modulation”:“LORA”,“bandwidth”:125,“spreadFactor”:9},“adr”:false,“codeRate”:“4/5”},“fCnt”:1047,“fPort”:33,“data”:“AQABKQAAAAAAAA==”,“object”:null}
object stays null
But when it run it in jsfiddle is works.
https://jsfiddle.net/bzwjkme6/26/
Is my objects wrongly formatted?
Thanks
Q_Lion
July 10, 2018, 7:05pm
#3
Hi
On the Error topic there is nothing.
But on the App server log i get the following.
Jul 10 19:00:19 lora-srv lora-app-server[1643]: time="2018-07-10T19:00:19Z" level=error msg="decode payload error" application_id=6 codec=CUSTOM_JS dev_eui=xxxx error="js vm error: ReferenceError: 'atob' is not defined" f_cnt=1304 f_port=33
Jul 10 19:00:19 lora-srv lora-app-server[1643]: time="2018-07-10T19:00:19Z" level=info msg="handler/mqtt: publishing data-up payload" topic="application/6/node/xxxx/rx"
Jul 10 19:00:22 lora-srv lora-app-server[1643]: time="2018-07-10T19:00:22Z" level=error msg="decode payload error" application_id=6 codec=CUSTOM_JS dev_eui=xxxx error="js vm error: ReferenceError: 'atob' is not defined" f_cnt=1304 f_port=33
Jul 10 19:00:22 lora-srv lora-app-server[1643]: time="2018-07-10T19:00:22Z" level=info msg="handler/mqtt: publishing data-up payload" topic="application/6/node/xxxx/rx"
“‘atob’ is not defined”
aaaagggg looks like atob is not supported by the app server.
Q_Lion
July 10, 2018, 7:20pm
#4
Hi
is there a function on the app server that can decode from base64 to hex?
it wont allow my function to work.
var HEX = '';
atob(); is not supported and charCodeAt();
Why would you want to encode byte64 to hex?
// Decode decodes an array of bytes into an object.
// - fPort contains the LoRaWAN fPort number
// - bytes is an array of bytes, e.g. [225, 230, 255, 0]
// The function must return an object, e.g. {"temperature": 22.5}
return {};
Bytes is an array containing the byte values, it is not a string.
Q_Lion
July 10, 2018, 7:44pm
#6
Hi
the device results are in hex. My knowledge of bytes a very little, will go to google, lol
http://test.wi360.net/LoRaWAN_Protocol_FPort_and_FRMPayload.pdf
I don’t think it is. The document describes a payload of 10 bytes, the examples are printed in HEX for your convenience. The bytes
given to the Decode
functions are the actual byte values, not a HEX string.
Q_Lion
July 10, 2018, 8:28pm
#8
Hi
I did the following.
Data: AQAAKNzoqRJxtw==
HEX: 00010029000000000000
return {fPort:fPort,bytes1:bytes[0],bytes2:bytes[1],bytes3:bytes[2],bytes4:bytes[3],bytes5:bytes[4],bytes6:bytes[5],bytes7:bytes[6],bytes8:bytes[7],bytes9:bytes[8],bytes10:bytes[9]};
“bytes1”:0 ->hex:00
“bytes2”:1 ->hex:01
“bytes3”:0 ->hex:00
“bytes4”:41 ->hex:29
“bytes5”:0 ->hex:00
“bytes6”:0 ->hex:00
“bytes7”:0 ->hex:00
“bytes8”:0 ->hex:00
“bytes9”:0 ->hex:00
“bytes10”:0 ->hex:00
Does it look like i’m on the right track?
Q_Lion
July 10, 2018, 10:06pm
#9
Hi
I managed to do a decoding.
"object":{"AntiDismantled":0,"Gsensor":0,"charGing":0,"latitude":-24.672943353652954,"longitude":25.93713592733573,"volts":4.1}
if(fPort == 33){
function intFromBytes( x ){
var val = 0;
for (var i = 0; i < x.length; ++i) {
val += x[i];
if (i < x.length-1) {
val = val << 8;
return val;
var antiDismantled = bytes[0];
var Gsensor = bytes[1];
var charGing = bytes[2];
var volts = bytes[3];
volts = volts/10;
var byteArrayLAT = [bytes[4],bytes[5],bytes[6]];
var latTemp = intFromBytes(byteArrayLAT);
var byteArrayLNG = [bytes[7],bytes[8],bytes[9]];
var lngTemp = intFromBytes(byteArrayLNG);
var lat = 0;
var lng = 0;
}else{
}else{
}else{
return {};
Thank you very much for all your help, i see now what you mean by bytes.
Great you’ve solved the issue I’ve renamed the topic so that it is easier to find for others that want to decode the same payload!
sorry to raise an old thread, I am however battling with a codec for the WINEXT AN106 field tester.
I found this for Helium, however I need it for CS and just cannot seem to get it right.
This is what i have:
var lat = ((bytes[0] << 16) | (bytes[1] << 8) | bytes[2])
if (lat & 0x800000)
lat |= ~0xffffff;
var lon = ((bytes[3] << 16) | (bytes[4] << 8) | bytes[5])
if (lon & 0x800000)
lon |= ~0xffffff;
return {
{latitude: lat / (2.**23 - 1) * 90,
longitude: lon / (2.**23 - 1) * 180,
altitude: (bytes[6] << 8) | bytes[7],
accuracy: 0
Has anyone got this working?
For those looking, this seems to be working:
if (lat & 0x800000)
lat |= ~0xffffff;
if (lon & 0x800000)
lon |= ~0xffffff;
return {
latitude: lat / (Math.pow(2, 23) - 1) * 90,
longitude: lon / (Math.pow(2, 23) - 1) * 180,
accuracy: 0
