Deduplication configuration
Where can i change the default 200ms for DEDUPLICATION_DELAY? is this on gatewaybridge config file? i know you have explained here about why this should not be change but if the device is Class C then this wont be a problem right?
However , wanted to understand on what basis 200ms was set as default.
When a confirmed message is picked up by 2 gateways within 200ms , from which gateway downlink tx acknowledgement will be received. Is the based on rssi?
Could you please help me with this, thanks.
