Hi Experts!
I am facing an issue with the Lora gateway. The client sends an uplink message which is processed on the network server.
The network server sends a downlink message back to the client. This message arrives at the gateway but is delayed (2-5 seconds) or dropped.
to be more precise i observe the below from the Gateway Bridge Log:
Down frame on the MQTT topic
time=“2021-11-17T12:08:02.400196316+01:00” level=info msg=“integration/mqtt: downlink frame received” downlink_id=8a48da5d-46e2-48c7-a2c9-7c6093c72af2 gateway_id=cc028d20254ef002
time=“2021-11-17T12:08:02.400522107+01:00” level=debug msg=“sending message to gateway” gateway_id=cc028d20254ef002 message="{“msgtype”:“dnmsg”,“DevEui”:“01-01-01-01-01-01-01-01”,“dC”:0,“diid”:35400,“pdu”:“60f955c000a513000352ff0001f0bafc66”,“priority”:1,“RxDelay”:1,“RX1DR”:4,“RX1Freq”:868100000,“RX2DR”:0,“RX2Freq”:869525000,“xtime”:45317472929820996,“rctx”:0}"
time=“2021-11-17T12:08:02.4007861+01:00" level=info msg=“backend/basicstation: downlink-frame message sent to gateway" downlink_id=8a48da5d-46e2-48c7-a2c9-7c6093c72af2 gateway_id=cc028d20254ef002
[ 7 Timesync Messages zwischen Common Packet forwarder und Gateway Bridge ]
time=“2021-11-17T12:08:03.877385059+01:00” level=debug msg=“backend/basicstation: message received” gateway_id=cc028d20254ef002 message=”{“msgtype”:“dntxed”,“seqno”:35400,“diid”:35400,“DR”:0,“Freq”:869525000,“DevEui”:“01-01-01-01-01-01-01-01”,“rctx”:0,“xtime”:45317472931820996,“txtime”:6081.597612,“gpstime”:0}”
time=“2021-11-17T12:08:03.877633972+01:00” level=info msg=“backend/basicstation: downlink transmitted message received” downlink_id=8a48da5d-46e2-48c7-a2c9-7c6093c72af2 gateway_id=cc028d20254ef002
time=“2021-11-17T12:08:03.878014362+01:00” level=info msg=“integration/mqtt: publishing event” downlink_id=8a48da5d-46e2-48c7-a2c9-7c6093c72af2 event=ack qos=1 topic=gateway/cc028d20254ef002/event/ack
There is a time difference of 1.476 seconds between “downlink-frame message sent” to gateway and “downlink transmitted message received”.
- please help me to understand the factors which contribute to the above delay.
- kindly provide me documentation if any to understand the downlink message flow along with the explanation for every field of the downlink message in gateway bridge. Thanks in advance!
