This application was deleted, but the application is still “exist” under Applications.
Moreover, the Devices are still being shown in the deleted application but shows “object does not exists code 5”
Is this normal ?
Is this normal ?
Are you sure the application was deleted successfully? Did you delete the application through the web-interface?
Thanks for your reply.
We deleted the Application through the web-interface.
We do not know the authority level of us.
We guess the problem may be due to the Server Settings. After we send the problem to the Server Admin., problem was solved.
