Hello, I need some help because I’m getting crazy.
I have 2 sensors which sends messages to gw but it doesn’t represent on my application.
Here are screenshots:
This is from gw messages
And this is a message from my application where is in this sensor.
I don’t now what is happening.
Thanks for help!
These dates are derived from the time on the machine they are running on. Check your time settings, they are likely incorrect / not updating.
Hello! This solution is not working, because there is still desync between the messages that come in and those that
I believe the dates in the GW frames are based on the time in the gateway, and the ones in the sensor application are from the time on the Chirpstack server.
Looks like just the gateway time is off? (The dates in the sensor application are correct yes?), have you checked your gateways time settings?
I’ve checked time in gateways and it’s the same as Chirpstack.
So i don’t believe it’s date…
I’m looking for a solution.
I think my firewall is filtering downlink traffic but i dont know. I don´t have status messages of gw too.
