Hi brocaar,
I met a problem run the chirpstack server on a arm-v7 chip. I used a device joined the server and it works when the server restart by shell command “sudo reboot”. But if i shut down the power directly and turn the power again, the device activation data becomes the value last time it restart by shell commad “sudo reboot”.
I checked the postgresql, the last data is correct , but the activation showed in web is the next to the last one( here I rebooted the server with shell command). The Device Address and Network session key are wrong , Application session key is right.
Could that be fixed?
Thanks.
