I’m sending my devices data to AWS using SNS integration. I was using OTAA however I realize that using ABP I ll consume less battery.
The point is that in my device data comes only my devEUI by default as you can see in my post.
Is it possible to show the device address? Since I’m using ABP I need it, I also would like to print the device profile in order to send to AWS using SNS
- applicationID:“1”
- applicationName:“IOT-APP”
- deviceName:“monitoring”
*** devEUI:“0000000000000001”**rxInfo:[] 1 item
0:{} 14 keys
* gatewayID:"-------------------------"
* time:null
* timeSinceGPSEpoch:null
* rssi:-35
* loRaSNR:8.2
* channel:7
* rfChain:1
* board:0
* antenna:0location:{} 5 keys
* latitude:0
* longitude:0
* altitude:0
* source:“UNKNOWN”
* accuracy:0
* fineTimestampType:“NONE”
* context:“Y0svRA==”
* uplinkID:“95234574-f787-44e7-a6ae-1e405d6bf7e6”
* crcStatus:“CRC_OK”txInfo:{} 3 keys
- frequency:903700000
- modulation:“LORA”
loRaModulationInfo:{} 4 keys
* bandwidth:125
* spreadingFactor:7
* codeRate:“4/5”
* polarizationInversion:false
- adr:true
- dr:3
- fCnt:13
- fPort:2
- data:“AwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGQBVGQMG”
- objectJSON:"{“accavg”:0,“accrms”:25,“battery”:85,“bin0”:0,“bin1”:0,“bin10”:0,“bin100”:0,“bin101”:0,“bin102”:0,“bin103”:0,“bin104”:0,“bin105”:0,“bin106”:0,“bin107”:0,“bin108”:0,“bin109”:0,“bin11”:0,“bin110”:0,“bin111”:0,“bin112”:0,“bin113”:0,“bin114”:0,“bin115”:0,“bin116”:0,“bin117”:0,“bin118”:0,“bin119”:0,“bin12”:0,“bin120”:0,“bin121”:0,“bin122”:0,“bin123”:0,“bin124”:0,“bin125”:0,“bin126”:0,“bin127”:0,“bin128”:0,“bin129”:0,“bin13”:0,“bin130”:0,“bin131”:0,“bin132”:0,“bin133”:0,“bin134”:0,“bin135”:0,“bin136”:0,“bin137”:0,“bin138”:0,“bin139”:0,“bin14”:0,“bin140”:0,“bin141”:0,“bin142”:0,“bin143”:0,“bin144”:0,“bin145”:0,“bin146”:0,“bin147”:0,“bin148”:0,“bin149”:0,“bin15”:0,“bin150”:0,“bin151”:0,“bin152”:0,“bin153”:0,“bin154”:0,“bin155”:0,“bin156”:0,“bin157”:0,“bin158”:0,“bin159”:0,“bin16”:0,“bin160”:0,“bin161”:0,“bin162”:0,“bin163”:0,“bin164”:0,“bin165”:0,“bin166”:0,“bin167”:0,“bin168”:0,“bin169”:0,“bin17”:0,“bin170”:0,“bin171”:0,“bin172”:0,“bin173”:0,“bin174”:0,“bin175”:0,“bin176”:0,“bin177”:0,“bin178”:0,“bin179”:0,“bin18”:0,“bin180”:0,“bin181”:0,“bin182”:0,“bin183”:0,“bin184”:0,“bin185”:0,“bin186”:0,“bin187”:0,“bin188”:0,“bin189”:0,“bin19”:0,“bin190”:0,“bin191”:0,“bin192”:0,“bin193”:0,“bin194”:0,“bin195”:0,“bin196”:0,“bin197”:0,“bin198”:0,“bin199”:0,“bin2”:0,“bin20”:0,“bin21”:0,“bin22”:0,“bin23”:0,“bin24”:0,“bin25”:0,“bin26”:0,“bin27”:0,“bin28”:0,“bin29”:0,“bin3”:0,“bin30”:0,“bin31”:0,“bin32”:0,“bin33”:0,“bin34”:0,“bin35”:0,“bin36”:0,“bin37”:0,“bin38”:0,“bin39”:0,“bin4”:0,“bin40”:0,“bin41”:0,“bin42”:0,“bin43”:0,“bin44”:0,“bin45”:0,“bin46”:0,“bin47”:0,“bin48”:0,“bin49”:0,“bin5”:0,“bin50”:0,“bin51”:0,“bin52”:0,“bin53”:0,“bin54”:0,“bin55”:0,“bin56”:0,“bin57”:0,“bin58”:0,“bin59”:0,“bin6”:0,“bin60”:0,“bin61”:0,“bin62”:0,“bin63”:0,“bin64”:0,“bin65”:0,“bin66”:0,“bin67”:0,“bin68”:0,“bin69”:0,“bin7”:0,“bin70”:0,“bin71”:0,“bin72”:0,“bin73”:0,“bin74”:0,“bin75”:0,“bin76”:0,“bin77”:0,“bin78”:0,“bin79”:0,“bin8”:0,“bin80”:0,“bin81”:0,“bin82”:0,“bin83”:0,“bin84”:0,“bin85”:0,“bin86”:0,“bin87”:0,“bin88”:0,“bin89”:0,“bin9”:0,“bin90”:0,“bin91”:0,“bin92”:0,“bin93”:0,“bin94”:0,“bin95”:0,“bin96”:0,“bin97”:0,“bin98”:0,“bin99”:0,“model”:3,“samplerate”:1536,“temperature”:25,“type”:3}"
- tags:
