Device always shows as **Last seen: Never**
024/10/24 00:14:16 DEV[d2] |Activation| {A}: Unjoined
2024/10/24 00:14:16 DEV[d2] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:16 DEV[d2] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:16 GW[G1]: PUSH DATA send
2024/10/24 00:14:17 GW[G1]: PULL ACK received
2024/10/24 00:14:18 GW[G1]: PUSH ACK received
2024/10/24 00:14:19 GW[G1]: PULL RESP received
2024/10/24 00:14:19 GW[G1]: TX ACK sent
2024/10/24 00:14:23 DEV[d1] |Activation| {A}: None downlink received
2024/10/24 00:14:23 DEV[d1] |Activation| {A}: Unjoined
2024/10/24 00:14:23 DEV[d1] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:23 DEV[d1] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:23 GW[G1]: PUSH DATA send
2024/10/24 00:14:24 GW[G1]: PUSH ACK received
2024/10/24 00:14:25 DEV[d2] |Activation| {A}: None downlink received
2024/10/24 00:14:25 DEV[d2] |Activation| {A}: Unjoined
2024/10/24 00:14:25 DEV[d2] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:25 DEV[d2] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:25 GW[G1]: PUSH DATA send
2024/10/24 00:14:25 GW[G1]: PULL RESP received
2024/10/24 00:14:25 GW[G1]: TX ACK sent
2024/10/24 00:14:26 GW[G1]: PUSH ACK received
2024/10/24 00:14:27 GW[G1]: PULL RESP received
2024/10/24 00:14:27 GW[G1]: TX ACK sent
2024/10/24 00:14:34 DEV[d2] |Activation| {A}: None downlink received
2024/10/24 00:14:34 DEV[d2] |Activation| {A}: Unjoined
2024/10/24 00:14:34 DEV[d2] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:34 DEV[d2] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:34 GW[G1]: PUSH DATA send
2024/10/24 00:14:35 DEV[d1] |Activation| {A}: None downlink received
2024/10/24 00:14:35 DEV[d1] |Activation| {A}: Unjoined
2024/10/24 00:14:35 DEV[d1] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:35 DEV[d1] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:35 GW[G1]: PUSH DATA send
2024/10/24 00:14:35 GW[G1]: PUSH ACK received
2024/10/24 00:14:36 GW[G1]: PULL RESP received
2024/10/24 00:14:36 GW[G1]: TX ACK sent
2024/10/24 00:14:37 GW[G1]: PUSH ACK received
2024/10/24 00:14:43 DEV[d2] |Activation| {A}: None downlink received
2024/10/24 00:14:43 DEV[d2] |Activation| {A}: Unjoined
2024/10/24 00:14:43 DEV[d2] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:43 GW[G1]: PUSH DATA send
2024/10/24 00:14:43 DEV[d2] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:44 GW[G1]: PUSH ACK received
2024/10/24 00:14:45 GW[G1]: PULL RESP received
2024/10/24 00:14:45 GW[G1]: TX ACK sent
2024/10/24 00:14:45 DEV[d1] |Activation| {A}: Downlink received
2024/10/24 00:14:45 DEV[d1] |Activation| {A} [ERROR]: lorawan: the max value of RXDelay is 15
2024/10/24 00:14:46 GW[G1]: PULL DATA send
2024/10/24 00:14:47 GW[G1]: PULL ACK received
2024/10/24 00:14:47 DEV[d1] |Activation| {A}: ACK Timeout
2024/10/24 00:14:47 DEV[d1] |Activation| {A}: Unjoined
2024/10/24 00:14:47 DEV[d1] |Activation| {A}: JOIN REQUEST sent
2024/10/24 00:14:47 DEV[d1] |Activation| {A}: Open RXs for 0 and 923300000
2024/10/24 00:14:47 GW[G1]: PUSH DATA send
2024/10/24 00:14:48 GW[G1]: PUSH ACK received
2024/10/24 00:14:49 GW[G1]: PULL RESP received
2024/10/24 00:14:49 GW[G1]: TX ACK sent
ConfirmDataUp and ConfirmDataDown not coming on the lora frames or event in the chirpstack server.
Device always shows as Last seen: Never
That looks suspicious and might be the root of your issue.
