I want to automatically integrate a large number of devices. For this I tried to use the method based on a request.
I deliberately masked the sensitive data but I checked them all one by one and they are correct.
curl -v -X POST
http://127.0.0.1:8080/api/devices
-H ‘Grpc-Metadata-Authorization: Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx’
-H ‘Content-Type: application/json’
-d ‘{
“device”: {
“applicationID”: “xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx”,
“devEUI”: “0095xxxxxxxxxxxx”,
“deviceProfileID”: “xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx”,
“skipFCntCheck”: false,
“referenceAltitude”: 0,
“name”: “CS-TEST”,
“description”: “load”,
“tags”: {},
“variables”: {},
“isDisabled”: false,
“skipFrameCounterValidation”: false,
“aDRInterval”: 0,
“aDREnabled”: true,
“maxSupportedDR”: 5,
“rxDelay”: 0,
“rx1DROffset”: 0,
“rx2DR”: 0,
“rx2Frequency”: 869525000,
“factoryPresetFreqs”: ,
“pingSlotFrequency”: 0,
“pingSlotDR”: 0,
“nwkSKey”: “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”,
“appSKey”: “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx”,
“fCntUp”: 0,
“fCntDown”: 0,
“lastDevStatusRequested”: 0,
“lastDevStatusAnswer”: 0,
“lastDownlinkTX”: 0,
“referenceLocation”: {
“latitude”: 0,
“longitude”: 0,
“altitude”: 0,
“source”: “source-of-location”
}’ -o response_log.txt --no-sessionid --silent
My request fails systematically with the following return
- Trying 127.0.0.1:8080…
- Connected to 127.0.0.1 (127.0.0.1) port 8080 (#0)
POST /api/devices HTTP/1.1
Host: 127.0.0.1:8080
User-Agent: curl/7.81.0
Accept: /
Content-Length: 1059
} [1059 bytes data]
- Mark bundle as not supporting multiuse
< HTTP/1.1 400 Bad Request
< content-length: 0
< date: Thu, 11 Jan 2024 12:51:14 GMT
< - Connection #0 to host 127.0.0.1 left intact
Can you tell me the reason for this error or give me another way to achieve this integration?
