Device not yet activated
I installed the chirpstack-application-server and the gateway is seen but the device does not. I am trying to set the parameters of the device for the network at the “activation” tap, but there I find “This device has not (yet) been activated” . what is the problem ?
Regards
in Device EUI or AppKey or directly in the device itself
look into the gateway live frame tab first.
try sending a join request from the device if using OTAA
@eugenev Thank you eugenev for response … the problem was that the gateway is seen but the device is not . however, it is solved. When using the OTAA seems that it is a must to send a join request.
@lachlanp Thank you lachlanp, the answer is as you say ! … seems that it is a must to send a join request when using OTAA. Thanks again.
I am having the same issue at the moment.
When we say “try sending a join request from the device if using OTAA”
What is it means and how can we send this from device??
I searched for the reason why my gateway doesn’t see my new device and found this thread. Based on what I saw on the serial monitor listening on the UART, I prepared all the needed configurations for this device.
It’s strange; my Lora E5 Mini didn’t send any JOIN command at all!
Is it destroyed? I changed the period between transmissions from 10 seconds to 60 seconds, but I don’t think that is the problem.
However, if my device didn’t send JOIN, which way might the gateway see it?
I think I have to change the Lora device for my sensor and try again.
